by Fraggboy » October 2nd, 2008, 9:34 am
wannaroomba,
It has been brought up before in multiple posts. The cause could be differnet issues tho. How long have you had your Roomba? When you say you tried taking the whole thing apart, did you take out the CHM (Cleaning Head Module which holds the brushes) and take that apart? Do you have pets?
If you have pets, you have a higher chance that pet hair has ended up in the CHM, hindering operation of the brushes. Now, even if you do have pets, the CHM might have stopped working due to other reason(s). You can verify if the brushes are actually turning by running the Roomba with the dust bin off. You can run it on carpet, and in the kitchen for less drag to see if the brushes are actually turning or not (IF you can run the Roomba at all).
Website Question? Check out the
FAQ section.
Roomba/Scooba Question? Check out the
READ FIRST section.
Before posting, check out the improved
Search engine. Your question might have been answered already.
