Roomba 550 Cliff Sensors -- New Fix
Re: Roomba 550 Cliff Sensors -- New Fix
Postby Sagrat » November 2nd, 2018, 8:57 am
I just want to temporarily "disable" the cliffs sensors at the back of the robot to see if it works correctly (if it's move).
Sagrat
Postby vic7767 » November 2nd, 2018, 11:25 am
To see how your Roomba will operate, place it into the built in tests program and test all sensors and motors. To learn how and what the tests do read this document from iRobot 500 series service manual:
Postby Sagrat » November 2nd, 2018, 12:36 pm
I already "test" the cliff sensor. The fourth front sensors are OK but the two at rear don't work. One has an defect IR LED and other don't emit IR light. I checked the IR with a camera to see if they emit a light. The front LED are OK but not the two back LED.
Have you a link for service manual for 800 series ?
Sagrat
Postby vic7767 » November 2nd, 2018, 1:39 pm
The same service manual can also be used for the 600 through 900 model Roombas. The ability to monitor the SCI channel will be of great benefit for the later models due to additional tests as well as additional test results.
Users browsing this forum: lanchez and 109 guests
