Roomba 5xx Series Lighthouse and Virtual Wall Information
Re: Roomba 5xx Series Lighthouse and Virtual Wall Informatio
Postby a1robotrepair » April 27th, 2016, 7:55 pm
Same Same
Postby babakonda » April 27th, 2016, 8:03 pm
Perfect, thanks for the quick reply! We are so damned in Europe - in my country, a 8xx lighthouse (older model, not the new square one running on AA) is sold for about $75/piece. The white ones can be found on european ebay for <$10. :D
babakonda
Postby vic7767 » April 27th, 2016, 8:53 pm
If your 7XX or 8XX Roomba has the builtin RF module then the 5XX model Lighthouse accessory will work with it.
Postby NoJimForHome » December 31st, 2018, 1:02 am
babakonda wrote:OK, just tried Scooba VW with Roomba 880.
Scooba VW seems to have significantly wider "beam" (as well as larger halo diameter) than my two black newer lighthouses (set in VW mode) which came packaged with Roomba.
Also, my Roomba seems a bit confused when it encounters Scooba's VW: it spins in circles in one spot, then goes 2cm further and continues to rotate in place etc. - I have tried that in several settings, with the same result. Not sure if that's normal as it never did it around 'normal' VWs.
Yep. Just got a pair of Scooba VWs on eBay for $16 shipped. Same behavior from the Roombas... somehow magically even around corners. If Roomba gets too close to the Scooba VW, it sits and spins for a moment, as described above.
I'll try using tape (mentioned above) to see how that impacts the Roomba behavior. But I *did* get them to keep Scooba off the rug, so it's not that big of a deal. Now I wish my Roombas had RF for LH purposes... sounds cool. :)
NoJimForHome
Postby babakonda » December 31st, 2018, 9:50 pm
I just spent a day trying to reset lighthouses around the house (as I keep them in wall mode) and get them to work with newly acquired Roomba 866. Apparently, the 866 doesn’t have RF :D took me a day to remember it LOL.
The old auto-on walls are nowhere to be found in Europe...if any pop out, they’re around €50 which is almost the cost of new dual-mode wall. I have two of them which I normally use with Scooba 450 so resetting paired them with 866.
babakonda
Postby NoJimForHome » January 14th, 2019, 7:34 pm
Quick question - I bought one of these for a good price:
Not sure if it'll work for me though because none of my robots have wifi (all too old.) I sort of assumed this thing would have a "manual" mode, but it doesn't appear that it does. Is that accurate?
NoJimForHome
Postby vic7767 » January 14th, 2019, 7:55 pm
It requires an RF equipped Roomba to handshake with and activate the accessory. The Roomba and Lighthouse use Zigbee hardware.
Postby NoJimForHome » January 14th, 2019, 8:16 pm
Avast. Well, I bought my in-laws a newer robot for Christmas, maybe it'll work at their house. Dunno.
NoJimForHome
Postby vic7767 » January 14th, 2019, 8:38 pm
This info is available on the iRobot website:
Only compatible with select Roomba 500 Series models, Roomba 780 and 790 and Roomba 877 and 880. Compatible 500 Series Robots include: 571(01), 571(02), 572, and 573.
Also some 535 and 560 models.
Postby NoJimForHome » January 14th, 2019, 10:42 pm
Avast! I got them an 805, which requires the one that looks like a coffee grinder. Wonder why they have so many variants. :/
NoJimForHome
Postby babakonda » January 15th, 2019, 3:42 pm
NoJimForHome wrote:Avast! I got them an 805, which requires the one that looks like a coffee grinder. Wonder why they have so many variants. :/
Those won't work with 805 at all. Not even in the virtual wall mode (not the lighthouse mode), unfortunately.
e.g. they work with my 880 but not with 866.
A quick question: would they work with 980 or the 980 isn't RF equipped?
babakonda
Postby vic7767 » January 15th, 2019, 3:46 pm
The 900 series as well as the i7 and e series do not have the RF Zigbee transceivers.
Users browsing this forum: BCCISProf, BrettS, cdogstu99, dariuszbednorz, johnnyh and 365 guests
