You have no idea of how that 550 came to be in the hands of an eBay seller, I presume. You probably assume (about all that can be done) that the unit was never used by a prior owner, such as for a 30-day trial, then returned for credit.cp1972 wrote:I purchased...{550} brand new from a US seller on eBay in Dec 2009. ...was shipped... to Australia, where we use 230V.
Output-voltage is one important parameter when specifying or talking about a step-down xfmr, but, it is also necessary to specify its power handling capability, in terms of watts, or volt*amps....I plugged the power supply (only) into a step-down voltage transformer (output 110V),
I cannot fathom how a step-down transformer can damage a Roomba PSU, except for a case in which the xfmr's power rating is grossly in excess of that required for this job. Such a xfmr would be too heavy for you to lift (for it to exhibit a too high no-load VAC) and too expensive! If anyone can explain how a properly rated (voltage ratio and power rating) xfmr can harm a switch-mode PSU, I wish they would say something.... and the iRobot power supply started emitting smoke... {&} died that day.
This is the hot season down-under, and that may be causing a PSU shut-down.Then I purchased a "Universal" iRobot Powersupply (110-240V input) ..., and it all worked beautifully for almost 2 months. ...After 2 months of daily usage it started reporting "Charging Error 5", and the battery pack seemed to die. It would charge EXACTLY 30 minutes, then report the error.
That would suggest the PSU is not powering Roomba into Charging-Mode, and suggests a duff PSU. Then you say:... After trying all the resets and all the other recommended solutions I could find... the battery finally didnt charge at all (Not even the red LED lights come one now, when the original battery pack is installed).
Which suggests: The good initial performance with #2- batt might have been obtained via its pre-purchase state of charge, after which your duff PSU failed to actually charge the battery. Its hard to be sure....I purchased another battery pack ... a NiMH, 14.4V 3300mAh. (original battery was a Ni-CD, 2200mAh). {and} This new battery charged on the first day, and the robot was happily running around for 1 hour, before returning to the base station, to charge again. It charged for app. 1 hour before reporting the same error. ... but now it will only charge for 20 minutes at a time, and the robot only manage to run for 5 minutes ...
24 hours would not have resulted in much self-discharge, fortunately for you and batt-#2! FYI, you never want to "completely" drain all charge (Roomba only permits charge to be removed until terminal voltage reaches 12V), NOT zero-volts)....and left the battery out for up to 24 hours, to completely drain the power ...
Either no reply will be sent, or, if one is received it will be a form letter telling you to deal with iRobot's off-shore contractor in Australia.I also wrote iRobot, on their website, 2 weeks ago, but haven’t heard a thing back from them.
You must decide to get technically involved, or just guess at what item to replace, buy it and try it.What should I do?
Definitely a dud!cp1972 wrote:...The voltage meter couldn’t read a steady current {voltage} on the PSU, it was fluctuating rapidly up and down between approx. 10V and reading a maximum of 17.7V .
I doubt you will be able to restore batt-#1. Batt-#2 should come out of this bad start-up, OK.I also tried measuring the battery packs, and the original one now has a reading of 4.68V and the one I purchased as a replacement had a reading of 14.36V.
Too late at night for me to get into that, but I can give some ideas about it tomorrow....Considering the warnings about how to get the packs charged to avoid damage, I don’t have much idea how to do it at the moment. I have a Sony Vaio Laptop charger that delivers 19.5V/4.7A – I am in doubt if this is enough to charge the battery or not, and also, ... – I would have to go with the direct connection (as described in the other posting).
The pair of contacts located central in the pack connect to the pack's 10k ohms (25C) thermistor -- keep voltage away from them. The two contacts which are in-line with a row of cells are the plus and "minus" ends of two cells (at ends of the 12-cell pack. I'll borrow one of vic7767's pix so you can see how those two cell ends just peek through that plastic frame:... I don’t know which is +/- on the battery pack as there are no markings,...
Use your DVM to check it. More often than not, the outer barrel will be the zero-volts side (referred to as (-)), and the center contact will be positive wrt to the barrel.... nor on the round plug on the power supply ...
That voltage should take it most of the way -- putting battery voltage into a safe region. However, a word of caution. A discharged battery can draw a lot of current at start of charging, and this one might task a high fraction of that PSU's 4.5A capability! No sweat for the PSU, but I would not like to stress my battery that way. I think it would be wise to figure out some way to connect some ballast resistance in series with that charging loop....and also a head up if the 19.5V would work to charge it up a bit,...
Looks good, and would work for Scooba too.... I used a travel inverter ...: Input: 220-240V / 50/60Hz & Output: 110 V AC / 100W MAX ...
Look on this page...Status now is that the new PSU has been shipped and I am awaiting it to check that it solves the problem (P.S. good customer service by the way!). ...
I can't come up with a simple approach to providing that ballast-resistor. Something would have to be purchased, which could be looked upon as a waste for a one-time application. Instead of using that resistor, I have an alternate process you could try. Call it "burst-charging with temperature and voltage guidance". Here's how I would do it:Gordon wrote:Gordon wrote:... I think it would be wise to figure out some way to connect some ballast resistance in series with that charging loop. ... I doubt you will have anything like that {3-ohm, 25W power resistor} lying about the house. I'll give it further thought tomorrow.
Users browsing this forum: a4refillpad, vic7767 and 104 guests
