Charging Error 3
Re: Charging Error 3
Postby jeanm » September 22nd, 2017, 12:26 pm
Hello everyone,
Thank you for the precious information I found on this forum.
I own a roomba 630 which was stored for 2 years in the basement. When I tried to charge the battery, I got the charging error 3.
Following your advice and suspecting corrosion, I took a closer look at the motherboard. To my surprise, I found no corrosion but a hole in the VBAT sector and small damage on the GND.
I attached a picture of the motherboard. Is there anything to do?
Picture of the motherboard.
Zoom
Anyway, thanks in advance for your advice.
Jean
jeanm
Postby mfortuna » September 22nd, 2017, 3:11 pm
I don't think that is an issue. Just less than perfect soldering.
Postby fabriciopk » June 1st, 2018, 5:28 pm
Hello everyone,
I had the same issue with U8 op-amp, when I turn on the robot it states charging error 3 always. But in my case, I think, was a lot worst. I tried to remove the IC and resolder it, but unfortunately I was unable to put it back because most of IC pad's were damaged by corrosion.
https://photos.google.com/share/AF1QipNFMP4PVE6Vk4Wo402h3NZQ_i7DAT4-RG78jP9PLQSk7ObcSbPg1ykxU2UbuMPnDg/photo/AF1QipO0OrUdE2ZGqipUiMptrlIbkZ94qwokssFDRiAD?key=OFczTnBLQkRBMHF4b3B1eGV0aU9iOVNnNndVejh3
fabriciopk
Users browsing this forum: Atena, daniellee0412, fuzzydunlop, johnnyh and 376 guests
