If you have been using that Scooba for some time, I think you may be locked in on the wrong tank chamber. IOW, the waste chamber's sensor may be causing the start up fault.greenturtle36 wrote:...There's something wrong with my scooba tank. Whenever I turn it on it goes automatically to "check tank" before I can even push "clean". ...
The "waste-full" sensor electrodes ride inside the waste chamber of the tank; whereas, the "clean-empty" sensor electrodes reside inside the robot, and are integral with the fitting that plugs into the tank bottom. iRobot calls that inlet fitting a "valve", but it is NOT a valve.greenturtle36 wrote:is the sensor on the tank, or on the scooba itself?...
Considering all the tank soaking and shaking effort you have endured I thought you might like to have a look-see inside the waste chamber to actually see those bloody waste-full sensor electrodes, what they look like and where they are located. If you do, then click this link: http://gsplews.lkgnet.com/gsp/Scooba/4. ... tm#%C2%A72 , followed by looking & reading.greenturtle36 wrote:... It's soaking in vinegar as we speak.
Users browsing this forum: Aussie_Frog and 119 guests
