Peter, I must tell you that I have very little confidence in what that '"french gadget reviewer" has to say about power consumption. I did some quick calculations showing the "27W" value is too low, and the "4W" value is too high. I also think that 40-mins per week of 1400W canister cleaning can't compare (on a floor area coverage basis) to 2 * 2h = 4 hours per week of Roomba floor sweeping. Based on these simple errors I tend to disregard their entire report.piokrza wrote:Just found some reviews of robotic vacs (french gadget reviewer: http://www.lesnumeriques.com) and want to compare them together. ...
Power-consumption comparative spec:
*Roomba 780:
27W /4W (charging/stand-by)
€6/year more expensive in use than Dyson DC29 canister (regular use - twice a week) ...
__
** - Dyson DC29 Allergy Canister; power: 1360W (declared: 1400W; efficiency comparable to regular 2000Watt vac) €5/year (when used twice a week for 20 minutes; other >2000W vacs - €6.5/year), 80 (tested)/82dB (declared)
gangel, when you say words like "roomba is doing his run" it makes me think you are measuring operating power of the robot while it is on a cleaning mission. Is that what you mean? If so, then your "1.1W" power value is not a valid number of watts; it would be more in the range of 20 to 30 watts.gangel wrote:... but im getting:
1.1W for when roomba is doing his run
4.1-6W when he is on trickle charge
It would be good of you to make two sets of measurements, one with the Home Base in use, and one while charging via Roomba's side jack.... when he finishes his run i can tell you what hes charging at.
My current thinking on that matter is: If the PSU can still charge Roomba's battery there will be no indication of excess power being used to operate the PSU. Power input should be on the order of 33 watts during the high-rate charging period. And, if the PSU's conversion work failed to also upgrade or remove the original MOV, it probably removed itself (by exploding). You would have to look inside the PSU's case to learn whether that happened.I bought a little machine that tells me all the values, so ill write them in. Hoping somone can interpret if the power mod was ok or if it was botched
gangel wrote:Hey gordon:
"doing his run" is measuring home base power use whilst roomba isnt on it (getting 1.1W)
whilst he is charging after a run i get 31-32W for about... an hour and a half charge
Whilst he is sitting on base overnight etc he gets ~4-6W
I havent worked it via the jack yet, ill do that if you think i need to
Peter, to claim that "...data taken from lesnumeriques would be true" is simply too all encompassing. One must select single elements which to apply true or false claims. As an example I will review your quoted gangel data:piokrza wrote:gangel wrote:Hey gordon:
In this situation these data taken from lesnumeriques would be true...
Peter, I wish to numerically challenge three errors that I see in the Roomba / Dyson data that was published by lesnumeriques. While I must now postpone any further comments about Roomba's "4W" trickle charging power, I would like to attempt correction of these errors that lesnumeriques is propagating. They are:piokrza wrote:Just found some reviews of robotic vacs (french gadget reviewer: http://www.lesnumeriques.com) and want to compare them together. ...
*Roomba 780:
__
Users browsing this forum: No registered users and 104 guests
