Dirt dog failed test 10 and all higher tests
Postby newmom » March 21st, 2012, 10:40 am
After I got so much help from this list on repairing my 400, I got up the courage to see if I could fix my old Dirt Dog. The Dirt Dog is still covered by Hammacher Schlemmer but I hate to return it because I liked it so well before it died. Anyway, when I got through diagnostics past the test 9, I was feeling pretty good. But then at test ten, it made a sickly toned noise and none of the tests past that seem to do much of anything at all.
When I try to use it , it moves a little as if it is in molasses, and attempts to circle and wall follow but just can't seem to do it. The front wheel does move freely and the wheel holder is clean. Manual rotation shows no change from the solid red light.
I imagine my advise will be to send it back, but having just learned how to use the diagnostic tests, I really wanted to try to see if it could be repaired first.
What do ya think?
New Mom to four irobots
newmom
Re: Dirt dog failed test 10 and all higher tests
Postby Fraggboy » March 21st, 2012, 11:02 am
I'm sure you could repair it, once Ed, or someone else points you in the right direction. They can also give you a better idea if you should repair it, or exchange it.
:confusion-shrug:
Fraggboy
Postby newmom » March 21st, 2012, 11:29 am
A quick update, I am still learning. I just realized the DD doesn't have an impeller so that threw me off a bit on my tests. I guess it didn't fail that test. For some strange reason, my DD seems to be running a little better, but it still shows a solid red light during test 10 when I turn the front wheel with my hand. (not sure I am doing it right) Passes the brush test and during the spinning brush test, brush turns but slowly. When running the DD, the spinning brush turns at various speeds, from not turning at all, to a solid slower than normal turn. It will run for a few minutes (maybe longer but I don't push it) It has some normal pattern movement and some unusual pattern.
newmom
Postby mfortuna » March 21st, 2012, 12:14 pm
Is test 10 the front tach test? You may need to clean the wheel (it should have alternate white and black halves, it the white is too dirty it may cause an issue). You could try popping the wheel out and blowing some air up towards the sensor.
The brush could be slippage in the gearbox or between the brushes and gears. It could also be the motor is failing.
The parts from your other 400 could be used to fix the Dirt Dog BTW.
Postby vic7767 » March 21st, 2012, 3:32 pm
Here is the SCI output of a Dirt Dog undergoing the Built in Tests, and may help owners understand why some tests just don't seem to do anything.
factory-test 0 LEDS
factory-test 1 bumpers
(bump-left?) PASS
(bump-right?) PASS
factory-test 2 cliffs-side
wiff: cliff-left on 2844 off 3576 signal 732 on? 0
wiff: cliff-front-left on 2165 off 3539 signal 1374 on? 0
wiff: cliff-front-right on 2896 off 3596 signal 700 on? 0
wiff: cliff-right on 3088 off 3612 signal 524 on? 0
wiff: wall on 3628 off 3628 signal 0 on? 0
(cliff-left?) PASS
(cliff-right?) PASS
factory-test 3 cliffs-front
(cliff-front-left?) PASS
(cliff-front-right?) PASS
factory-test 4 wheel-drop-and-wall
(wheel-drop?) PASS
(wheel-drop?) PASS
(wheel-drop?) PASS
(wall?) PASS
factory-test 5 rcon-receiver - To obtain a PASS, use a Virtual Wall
(rcon?) PASS
(any-remote-opcode?) PASS - To obtain a PASS, use a Remote Control
factory-test 6 battery-sensors
(battery-voltage-ok?) PASS
(baseline-current-ok?) mA -78 min -202 max -13 mV 16281 degrees-C 19 PASS
factory-test 7 left-wheel
not left-wheel-stall PASS
(drive-speed-ok? left forward) PASS
(left-drive-current-ok?) mA -141 min -326 max -117 mV 16003 degrees-C 19 PASS
wait: left-wheel-stall
(left-drive-stall-current-ok?) mA -434 min -749 max -397 mV 16142 degrees-C 19 PASS
wait: (not left-wheel-stall)
factory-test 8 right-wheel
not right-wheel-stall PASS
(baseline-current-ok?) mA -72 min -202 max -13 mV 16253 degrees-C 19 PASS
(drive-speed-ok? right forward) PASS
(right-drive-current-ok?) mA -130 min -326 max -117 mV 16170 degrees-C 19 PASS
wait: right-wheel-stall
(right-drive-stall-current-ok?) mA -432 min -749 max -397 mV 16031 degrees-C 19 PASS
wait: (not right-wheel-stall)
factory-test 9 wheel-encoders
(drive-speed-ok? left reverse) PASS
(drive-speed-ok? right reverse) PASS
factory-test 10 stasis - The Dirt Dog is not equipped with the IR Stasis circuit
disabled
factory-test 11 main-brush
not brush-motor-stall PASS
(baseline-current-ok?) mA -72 min -202 max -13 mV 16226 degrees-C 19 PASS
(brush-current-ok?) mA -449 min -566 max -208 mV 15947 degrees-C 19 PASS
wait: brush-motor-stall
(brush-stall-current-ok?) mA -1203 min -1901 max -1191 mV 15780 degrees-C 19 PASS
wait: (not brush-motor-stall)
factory-test 12 debris – The Dirt Dog is not equipped with the dirt detector hardware
disabled
factory-test 13 vacuum – 'The Dirt Dog dust bin is not equipped with the vacuum motor
disabled
factory-test 14 side-brush
not side-brush-motor-stall PASS
(baseline-current-ok?) mA -72 min -202 max -13 mV 16198 degrees-C 19 PASS
(side-brush-current-ok?) mA -137 min -247 max -52 mV 16114 degrees-C 19 PASS
wait: side-brush-motor-stall
(side-brush-stall-current-ok?) mA -156 min -423 max -98 mV 16086 degrees-C 19 PASS
wait: (not side-brush-motor-stall)
factory-test 15 int-charger-recovery
not (int-charger-available?) PASS
wait: (int-charger-available?)
(int-charging-recovery-current-ok?) mA 85 min 241 max 358 mV 16393 degrees-C 19 FAIL
factory-test 16 int-charger-on
(int-charging-current-ok?) mA 111 min 397 max 1602 mV 16309 degrees-C 19 FAIL
factory-test 17 int-charger-trickle
(int-charging-trickle-current-ok?) mA 46 min 33 max 72 mV 16365 degrees-C 19 PASS
factory-test 18 ext-charger-recovery
wait: (ext-charger-available?)
factory-test 19 ext-charger-on
factory-test 20 ext-charger-trickle
factory-test 21 bootloader
(bootloader-ok?) PASS
SUMMARY: START
SUMMARY: DATE-TAG AND BOARD-REV 2006-08-19-1814-L Roomba board revision: 2 (garage-bot-roomba)
SUMMARY: (bump-left?) PASS
SUMMARY: (bump-right?) PASS
SUMMARY: (cliff-left?) PASS
SUMMARY: (cliff-right?) PASS
SUMMARY: (cliff-front-left?) PASS
SUMMARY: (cliff-front-right?) PASS
SUMMARY: (wheel-drop?) PASS
SUMMARY: (wall?) PASS
SUMMARY: (rcon?) PASS
SUMMARY: (any-remote-opcode?) PASS
SUMMARY: (battery-voltage-ok?) PASS
SUMMARY: (baseline-current-ok?) PASS mA -72 min -202 max -13 mV 16198 degrees-C 19
SUMMARY: left-wheel-stall PASS
SUMMARY: (drive-speed-ok? left forward) PASS
SUMMARY: (drive-speed-ok? right stopped) PASS
SUMMARY: (left-drive-current-ok?) PASS mA -141 min -326 max -117 mV 16003 degrees-C 19
SUMMARY: (left-drive-stall-current-ok?) PASS mA -434 min -749 max -397 mV 16142 degrees-C 19
SUMMARY: right-wheel-stall PASS
SUMMARY: (drive-speed-ok? right forward) PASS
SUMMARY: (right-drive-current-ok?) PASS mA -130 min -326 max -117 mV 16170 degrees-C 19
SUMMARY: (right-drive-stall-current-ok?) PASS mA -432 min -749 max -397 mV 16031 degrees-C 19
SUMMARY: (drive-speed-ok? left reverse) PASS
SUMMARY: (drive-speed-ok? right reverse) PASS
SUMMARY: (stasis?) disabled
SUMMARY: brush-motor-stall PASS
SUMMARY: (brush-current-ok?) PASS mA -449 min -566 max -208 mV 15947 degrees-C 19
SUMMARY: (brush-stall-current-ok?) PASS mA -1201 min -1901 max -1191 mV 15780 degrees-C 19
SUMMARY: (debris-left?) disabled
SUMMARY: vacuum-motor-stall disabled
SUMMARY: (vacuum-current-ok?) disabled
SUMMARY: (vacuum-stall-current-ok?) disabled
SUMMARY: side-brush-motor-stall PASS
SUMMARY: (side-brush-current-ok?) PASS mA -137 min -247 max -52 mV 16114 degrees-C 19
SUMMARY: (side-brush-stall-current-ok?) PASS mA -156 min -423 max -98 mV 16086 degrees-C 19
SUMMARY: (int-charger-available?) PASS
SUMMARY: (int-charging-recovery-current-ok?) FAIL mA 85 min 241 max 358 mV 16393 degrees-C 19
SUMMARY: (int-charging-current-ok?) FAIL mA 111 min 397 max 1602 mV 16309 degrees-C 19
SUMMARY: (int-charging-trickle-current-ok?) PASS mA 46 min 33 max 72 mV 16365 degrees-C 19
SUMMARY: (ext-charger-available?) PASS
SUMMARY: (ext-charging-recovery-current-ok?) untested
SUMMARY: (ext-charging-current-ok?) untested
SUMMARY: (ext-charging-trickle-current-ok?) untested
SUMMARY: END
factory-test 0 leds
wait: false
processor-sleep
fake-key-wakeup
slept for 0 minutes 1 ticks
2006-08-19-1814-L
Just a small amount of charging data capture
2006-08-19-1814-L
battery-current-quiescent-raw 516 battery-current-zero 502
do-charging-wait-initial @ minutes 9
do-charging @ minutes 9
bat: min 9 sec 17 mV 16587 mA 638 deg-C 19
bat: min 9 sec 18 mV 16727 mA 645 deg-C 19
bat: min 9 sec 19 mV 16782 mA 638 deg-C 19
bat: min 9 sec 20 mV 16810 mA 638 deg-C 19
bat: min 9 sec 21 mV 16810 mA 645 deg-C 19
bat: min 9 sec 22 mV 16810 mA 638 deg-C 19
bat: min 9 sec 23 mV 16810 mA 645 deg-C 19
bat: min 9 sec 24 mV 16810 mA 638 deg-C 19
bat: min 9 sec 25 mV 16810 mA 645 deg-C 19
bat: min 9 sec 26 mV 16810 mA 638 deg-C 19
bat: min 9 sec 27 mV 16838 mA 645 deg-C 19
bat: min 9 sec 28 mV 16838 mA 638 deg-C 19
bat: min 9 sec 29 mV 16838 mA 645 deg-C 19
bat: min 9 sec 30 mV 16838 mA 638 deg-C 19
bat: min 9 sec 31 mV 16838 mA 645 deg-C 19
bat: min 9 sec 32 mV 16838 mA 638 deg-C 19
bat: min 9 sec 33 mV 16838 mA 645 deg-C 19
bat: min 9 sec 34 mV 16838 mA 632 deg-C 19
bat: min 9 sec 35 mV 16838 mA 645 deg-C 19
processor-sleep
Postby newmom » March 23rd, 2012, 7:03 pm
Lost me at SCI tests, This is all way over my head, but I am sure lots of other members understand what this means. I decided to return the Dirt Dog when I saw another one on Ebay that was almost new and cost the same as what I will get back from H and S. I guess it just made more sense. I still feel I learned a lot and if that DD hadn't been under warranty, I would have continuted with working on the front wheel problem. Thanks again for all the help, and I am going to keep the info Vic posted about the DD, because I don't give up easily and the time will come when it will be more meaningful to me.
I did just notice the remarks in slightly bolder print, which pertains to which tests don't apply to the DD, and now I am guessing that is the info you were thinking would be more helpful, and that is more helpful. You guys are GRREEEEEAAAATE
newmom
Postby vic7767 » March 23rd, 2012, 8:49 pm
Just save the SCI Dirt Dog text. It is just an ASCII story book of what the Built in Test program sees and reports either a PASS or FAIL of a particular test.
Postby mfortuna » March 24th, 2012, 7:08 am
SCI is the serial command interface. There is a DIN connector just above the charging jack but is commonly refered to as the SCI jack. If you attach the proper cable between this connector and a PC you can display the test information. You can also do cool things like control the robot. In the case of running diags it has nothing to do with SCI but is just used to display test information. When the robot sits on the dock or has the charger plugged in, this port will display charging information.
Postby newmom » March 24th, 2012, 10:58 am
So Cool. Where does one get a proper cable? Thanks for taking the time to explain this to those of us who don't have the background many of you have.
newmom
Postby vic7767 » March 24th, 2012, 12:09 pm
You can go directly to the iRobot web page then select "robots for the home" then select "accessories" then select "Create" then choose either the USB cable or if you have an older computer you can choose the DB9 pin connector cable. Here's a direct URL to the USB cable: http://store.irobot.com/product/index.j ... age=family
Postby newmom » March 24th, 2012, 12:11 pm
vic7767 wrote:You can go directly to the iRobot web page then select "robots for the home" then select "accessories" then select "Create" then choose either the USB cable or if you have an older computer you can choose the DB9 pin connector cable. Here's a direct URL to the USB cable: http://store.irobot.com/product/index.j ... age=family
Thanks for the link :thanks:
newmom
Postby mfortuna » March 24th, 2012, 3:23 pm
If you want to go wireless you can do that do, for even more of a "geek" factor. If you decide you would like to try that let us know.
Postby newmom » March 24th, 2012, 3:31 pm
Can you tell me if this item available on Ebay is the same thing I need?
http://www.ebay.com/itm/Roomba-OSMO-Ser ... 2eb0704438
newmom
Postby vic7767 » March 24th, 2012, 4:14 pm
No, that cable is for connecting a Scheduler remote to the Roomba to flash the firmware with the scheduler feature. It has no circuitry to allow communication between a terminal program on a PC and the serial interface in the Roomba.
Postby newmom » March 24th, 2012, 4:24 pm
Thanks for clarification.
newmom
Postby JEDi » January 2nd, 2013, 3:11 pm
mfortuna wrote:If you want to go wireless you can do that do, for even more of a "geek" factor. If you decide you would like to try that let us know.
How can I setup my Dirt Dog for wireless?
JEDi
Postby vic7767 » January 2nd, 2013, 6:31 pm
Your Dirt Dog has a built in interface (7-pin mini din) that is located just above the charger jack and is covered by a removable plastic cap. There is a device made for the Roomba called a Rootooth that provided a RF wireless interface. Using a PC or an Android app that has a bluetooth capability you can connect to the Roomba and send commands to it. Here is a URL to Amazon.com where you can read about and purchase the Rootooth.
http://www.amazon.com/RooTooth-Bluetoot ... s=rootooth
Users browsing this forum: djos and 97 guests
