by Twobeers » February 23rd, 2013, 7:09 pm
The round hole on the one side of the tank is the inlet, the square hole on the oposite side is the outlet. It may look clean, water rinses thru easily. Stick a water hose into the round hole & run water thru with moderate pressure for awhile. I did that to mine & got a piece that came out that resembled a piece of pet turd after 5 minutes. You can use your finders to alternately block some of the holes were water is flowing out to force into other passages more aggresively.
