FYI, BiTs 2 to 10 don't relate to wheel-motor operation, other than using certain data from that sensor set to help Roomba navigate while in Clean Mode.ji101 wrote:Hello, im new to this forums. ...I am the owner of a Roomba 531, and it started ... going un circles, clockwise, ... . I did some bulit in tests, and it seems it is not a sensor fault, because it recognizes my hand and slows down. And it passed tests 2 to 10 without problems.
Quite "wrong".When i ran wheel tests, BiT 12 is ok, it moves left wheel forward. But BiT 13 moves right wheel backwards, and i think this is wrong.
The three BiTs demonstrated the wheel motors to be operational. If, with the RH Wheel Module dismounted, you had applied a two polarities of dc test voltage to the RH wheel motor you would have seen it properly reverse wheel rotation. I.e., no need to replace the RH module.Test 13 is ok as it moves both wheels backwards. ...I replaced right wheel module but it made no difference at all. ...
Welcome. There is little chance that visual damage will have resulted (unless a component had been severely overheated), or seen in the photos you provided (especially at the scaled down resolution invoked by the pix-host). Your scenes ...121106-212308 and ...-212634 cover the bottom & top areas that include the Right Wheel Motor Driver's components. Anyone sleuthing this problem would need to get up close with optical magnification while looking for physical damage clues. Here are a couple pix (2nd is from your ...634 image) enclosing H-bridge components on bottom & top PCA sides:ji101 wrote:Thank you both for your help.
I managed to open Roomba and took pictures of the board. Do you see some component broken or something wrong? ...
matofill, please write what "Qnn" transistors you replaced. Were they: Q83 and Q63?matofill wrote:I have exactly the same problem, but right wheel was death... I open the motherboard and found that 2 transistors in PCB are defective one NPN and one PNP, ...
That seller claims to have repaired the mobo he has for sale. He does not report what was wrong with the board, nor what components he replaced. I would not care to do business with him. OTOH, his listed price is lower than you will find elsewhere. If you are a gambler, then give this guy a trial.ji101 wrote:Thanks for your time and help. I guess i'll go for a PCB replacement. Do you think this would be ok?
http://www.ebay.com/itm/ROOMBA-510-530- ... 3f1d83789e
Check the Buy / Sell / Trade forum to see if this eBay seller appears on the 'acceptable' or 'unacceptable' lists. The one seller that rr members have found trustworthy is "casino187". Here is his offering for some 5XX main_PCAs: http://www.ebay.com/itm/Roomba-500-Seri ... 27cc4a370eOr maybe I should go for a new one like this:
http://www.ebay.com/itm/NEW-iRobot-Room ... 3a7bf7ad29 ...
Gordon wrote:matofill, please write what "Qnn" transistors you replaced. Were they: Q83 and Q63?matofill wrote:I have exactly the same problem, but right wheel was death... I open the motherboard and found that 2 transistors in PCB are defective one NPN and one PNP, ...
Today, I am wondering why I quoted left-wheel example transistors(?).matofill wrote:No, the death transistors was Q59 and Q75, ...Gordon wrote:... Were they: Q83 and Q63?
Users browsing this forum: a4refillpad, vic7767 and 110 guests
