Scooba wheel issue
Scooba wheel issue
Postby robotjunky » November 8th, 2012, 9:13 pm
Can anyone tell me what is the issue with a wheel that does not think it is depressed? The left wheel has issues thinking it is not touching the ground and the Scooba will not start unless I press down on it with about 5 lbs pressure before hitting clean (I'm stuck error otherwise). Fails the test 5 also unless I press down hard. Is it the wheel or a sensor? Otherwise, the wheels feel and look identical.
Thanks!
robotjunky
Re: Scooba wheel issue
Postby robotjunky » November 9th, 2012, 1:06 am
Nobody here has seen this I guess... I did take the top open and plug the battery and run test 5 without the top and no spring pressure. there was no "check tank" problem and it passed. This sounds like a mechanical problem, but I am not convinced as this is a new - no warranty - Scooba.
robotjunky
Postby Koontzy » November 9th, 2012, 1:25 am
i'm gonna try to answer my best but there is lot more people way much qualified than me here :P
try to blow compressed air in the wheel assembly while tapping it few times
if this doesnt work, your probably gonna have to disasemble the wheel module and remove junk on the switch
(but i've never opened mine and i've also heard its pretty hard without breaking it)
Koontzy
Postby vic7767 » November 9th, 2012, 1:29 am
There is a small magnet installed in each drive wheel that operates a reed switch that is mounted on a small circuit board next to each motor. You might check to see if the circuit board is in place and that the small round magnet is also in place.
Postby robotjunky » November 9th, 2012, 10:01 am
Thanks so much! I will see if I can locate the magnet. That actually makes a lot of sense if it is askew!
robotjunky
Postby Gordon » November 9th, 2012, 11:39 am
robotjunky wrote:... I will see if I can locate the magnet. ...
You might find this article to be useful:
http://mysite.verizon.net/gsplews/19ReedSWs.htm
...and this one can help you extract the wheel asm from the chassis:
http://mysite.verizon.net/gsplews/11DrvWhl.htm
Regarding whether the magnet pellet is still where it belongs: My recollection is, once installed there is no way the pellet can escape without unscrewing parts to release it from its cavity.
Gordon
Postby robotjunky » November 9th, 2012, 12:56 pm
Thank you so much Gordon and Vic for your help! I discovered the little board was not installed all the way. I pushed hard and it slid down about 1/4 inch. The Scooba is now working! Yea!!!
robotjunky
Users browsing this forum: No registered users and 64 guests
