mfortuna wrote:You could buy some brass tubing, a bushing, or a bearing to fix the gear which looks to be in good shape otherwise. You may have to further enlarge the hole to get the repair to work. They key is to get something with an inner diameter that matches the shaft and an outer diameter as close as possible to the enlarged gear hole size.
A new battery and a repaired gearbox should keep you going.
swedish_petcleaner wrote:Thanks for all the help but I think modifying the CHM is a bit to time consuming for me.
If I understand you experts correctly the easiest solution then is to buy a new 700-series CHM? (modded if possible)
Users browsing this forum: 911medic, FlyingPolarBear, im1kissfan, KeldBroe, leonicholson, Miles267, someoneclever, sshephard, teokakav, vic7767 and 369 guests
