H-Bridge mini mod
H-Bridge mini mod
Postby vic7767 » November 20th, 2012, 5:18 pm
Although no-one has actually experienced a true hardware failure of the H-Bridge NPN/PNP bi-polar transistors used for the drive wheels on the 500, 600, and 700 Roombas, a little preventative mini mod can be done to improve the odds of never having the issue. Using a pair of cutters, one can form a set of heat sinks from something like a blank aluminum name plate. Just cut it into quarters then apply a dab of thermally conductive silicone adhesive and mount each strip to the back side of each transistor. The adhesive sets up hard in 24 hours.
Re: H-Bridge mini mod
Postby Gordon » November 23rd, 2012, 1:24 pm
Just a little side note, vic. As of the very next day (21st) we can no longer make this claim:
vic7767 wrote:Although no-one has actually experienced a true hardware failure of the H-Bridge NPN/PNP bi-polar transistors used for the drive wheels on the 500, 600, and 700 Roombas, ...
Member matofill reported in this post replacing two power xstrs in his R3-Roomba that effected operational repair. Communication with matofill brought forth data that strongly suggests his transistors failed due to some cause other than over-heating.
Gordon
Postby TechGuy » November 23rd, 2012, 2:40 pm
The other cause may be water damage as the H-Bridges are not covered by the plastic under the keypad.
I had repaired a 540 with one of the wheel running all the time with transistors failed shorted.
Cleaning Crew: Scheduler, Roomba Sage 4110 x3, Roomba Red x3, Disco x2, Roomba Original x6, Scooba 5900, Roomba 560, 581, 540, 530
For Sale: Black CHM 2 Ball Bearings set
Users browsing this forum: Methos, vic7767 and 99 guests
