Troubleshooters: Get a handle on fixing R3's Whl-Mtr Circuit
Postby Gordon » November 29th, 2012, 1:50 pm
I think we have seen numerous reports describing Roomba 500 (a.k.a., "R3") drive-wheel failures. Some have been due to busted tachometer magnets. Some reports talked about broken drop switches, and there may have been some in which the motor no longer worked.
This OP deals with none of those failures. The failure modes this OP should help with are ailments where the motor passes a stand-alone power check (the ubiquitous "9V battery" applied to spin the motor check) but the motor won't respond while being powered by its own robot.
Some members have pulled their robot out of those doldrums by replacing one or more of the motor-driver's H-bridge power transistors, however, a subset of those transistor replacers have not met with success, and, were then left to ponder what other devices in that wheel-motor driver circuit might have failed.
Lacking schematic diagrams for R3 H-bridge circuits, the only help I could offer was to point at R2's (4XXX Roombas) wheel-motor driver schematic(s) while saying something like: "R3's circuit ought to be somewhat the same..., blah, blah.".
Member latzka's plight prompted me, this month, to journey around R3's main_PCA copper tracks to visit each of the semiconductors and passives that form a wheel-motor driver circuit. Now it is clear to me that what I said in the past about this circuit was rubbish!
Once one goes outside of the H-bridge core (i.e., the four power xstrs that we envision as forming vertical lines of a capital "H", the electric motor and its pigtail wires that form the horizontal bar between the uprights, and four power diodes (used to snub voltage generated every time motor power is cut off)), thus, nine components in all, the 5XX, and 6XX wheel-motor driver circuits differ greatly when compared to the design used in the Roomba Discovery series.
See for yourself. Compare the following image with either schematic2 or schematic5 (find by searching this board).
{THIS IS A DRAFT VERSION.}
Here are a few other things to think about that drawing:
    1) It may not be 100% correct (even after discounting that none of four input / control signals are precisely known).
    2) Via deduction I asserted what those signal functions might be. Instrumented (O-scope) measurements may be needed to confirm. Three of them appear to have no direct connection to the MCU, marker U28, yet the MCU must source those signals.
    3) I have not performed rigorous checking accuracy (but did discover, and correct a couple errors that were revealed while I drafted tables of logic states (tables attached later)). Relative to "accuracy", I have to point out that I purposely omitted showing four components (two are certainly insignificant, and two are poor candidates towards disabling this circuit). Here they are:
      a) Two each zero-ohms jumper 'resistors' that carry motor current to/from sockets of card-edge receptacle J16.
      b) Two each ceramic capacitors that suppress conducted motor EMI, which also board mount near J16. Schematically, these caps parallel diodes D52 & D53.{edited to change "D25" to "D52".}
    4) 'On paper' the circuit looks quite reasonable, quite functional, but bear in mind that what you see is all based on continuity checks, resistance measurements, visual identities, and latzka's live data. I did no live-board measurements to support this project.
Here is another copy of Right Wheel circuit, but symbolically powered up and running its wheel in a direction corresponding to forward travel of the robot:
Without member latzka's xstr base measurements, that he reported over here...: viewtopic.php?p=111779&sid=a3e6fa68892e57f24d5b0cbaea9fd557#p111779
..., I doubt I would have been able to assign FWD (or REV) motor-current flow.
One major difference between R2 & R3 motor driver circuits is: increased complexity in R3's. I can indicate that difference by device and component counts. In the following counts I will not tally the four (bridge) power xstrs and their four power diode voltage snubbers in the following table. IOW, numbers are for the outliers beyond the H-bridge:
Code: Select all
Roomba version__| R2 | R3 |
Active devices__|..3.|..8.|
Passive devices_|..9.|.22.|
Component count_|.12.|.27.|
From a EE's viewpoint the R3 motor driver circuit may be seen as better behaved than was R2's. But it should also be obvious that reliability of that performance is suspect when the peripheral parts' count is more than double that in the R2 circuit. When system performance is important the main tactic used to assure reliable performance is to build with certified-reliability components. I don't mean aerospace high-rel level components should be used in floor-sweepers, but only suggesting that iRobot might have to avoid buying electronic components at "minimum-bid" cost level.
Having a greater number of failure points built into this R3 circuit may help explain wheel-drive failures that can't be corrected by trial replacement of H-bridge power transistors. There are many opportunities for failure between the H-bridge and the MCU control source. Failure of any one gate in U6, or a diode in dual diode packages D11 or D12, can cause a migraine to a troubleshooter working without a schematic diagram.
Thus, with that in mind I have created and attached two tables of test points that a troubleshooter might use to narrow down the faulty area in this circuit. These are Tables of Bias States, one with motor running forward, and the other with the motor rotation reversed.
FWD-TableOfBiasStates.pdf
(20.16 KiB) Downloaded 387 times
REV-TableOfBiasStates.pdf
(20.15 KiB) Downloaded 382 times
Readers may wonder whether a Left Wheel Motor Driver schematic diagram has been prepared. No. But, I have seen (and spot checked left vs. right PCB constructions) enough to claim there is adequate similarity between the sides that anyone working at this detail level ought to be able to draft a schematic of the Left Wheel Motor Driver by using as a guide the right-side schematic and components' positions. By and large, the line drawings will be identical and only the component markers will differ.
Gordon
Re: Troubleshooters: Get a handle on fixing R3's Whl-Mtr Cir
Postby vic7767 » November 29th, 2012, 2:48 pm
WoW Gordon, great effort. I wondered what you were up to lately.
Postby TechGuy » November 29th, 2012, 6:53 pm
Thanks Gordon.
I found a couple of 500 series Roomba with the value of the R138 1-ohm resistor changed to over 10 times higher than 1-ohm. This affects the Buck converter output +5REG.
I am wondering whether the zero-ohm resistors on the wheel circuit may change affecting the current delivered to the wheel.
Postby Gordon » November 29th, 2012, 11:29 pm
TechGuy wrote:Thanks Gordon.
Hope the OP helps you fix some things.
While googling (using sea-$: "re SMT zero ohms resistors how are they made?") to find answers for your "wondering" about the 0-ohm resistors shifting value I came across this page: https://en.wikipedia.org/wiki/Resistor which, about 4/5ths way down the page -- under "Failure Modes", talks about the start up stress put on a resistor, such as R138, by a SMPS like the buck convertor.
If you go to this page: http://www.analog.com/static/imported-f ... stors.html and scroll down about half way to the topic "Rectangular surface mount film resistors. / Thick film", you can read about just how poor the stability of thick-film carbon-comp resistors can be. Writers at this site: http://www.learningaboutelectronics.com ... -resistors place the resistance of zero-ohm resistors around 0.004 ohms. We can't argue against value drifting, so lets take a severe case in which drift amounts to factor 100X, giving a value of 0.4 ohms. The question then is: How might that higher value effect wheel drive?
Going to the 500 Series Service Manual: It tells us about normal and excessive BiTs limits:
left / right drive current 75 to 150 mA wheel motor
left / right stall current 700 to 850 mA wheel motor {I rearranged current values to make sense.}
At the momentary high limit of stall current the voltage drop across our 0.4 ohms jumper resistor would be: dV = 0.4 * 0.85 = 0.34 volts; which is a small fraction of battery voltage impressed across the series arrangement of two power xstrs and the motor. I can't see that as being disruptive. Operating in the "drive current" range would be even less concern.
Gordon
Postby Gordon » November 30th, 2012, 12:44 am
vic7767 wrote:WoW Gordon, great effort. I wondered what you were up to lately.
vic, thanks for the note of appreciation. I was hoping to snare one of the 'failed wheel-drive' posters to test my tables and report any errors, but looks like I'll have to troll the archives to ferret out those buggers!
My best resource, "latzka", side stepped his R3's fault by R&R-ing his ailing robot's mobo, so he is out of the picture for the moment.
Gordon
Postby vic7767 » November 30th, 2012, 11:38 am
I run into that fault once in a while, the next one I get I'll ship you the mobo.
Postby Gordon » November 30th, 2012, 8:18 pm
vic7767 wrote:I run into that fault once in a while, the next one I get I'll ship you the mobo.
Thanks for the enticement, vic. When that time arrives we can work the details.
I think before messing with a faulty main_PCA I should first take the lid off my 535 and check out the two tables using its wheel-drivers (drivers that function OK). In addition to verifying tabled logic statements I want to determine how badly nodes that carry PWM signals into the circuit tend to misconstrue "status" when a dc-voltmeter is the only available troubleshooting instrument.
I have no way of foretelling when I can steal time away from doing: what must be done; what I should do; or, what 'honey-do comes along, in order to insert what I wish to do into available hours. Therefore I have great difficulty scheduling any of my "wish-to-do" tasks!
Gordon
Postby a1robotrepair » May 3rd, 2016, 4:46 pm
Thanks for the time and patience to put those drawings together Gordon!
I just fixed a 770 with a CHM problem but couldn't find a logical way to make your drawings work.
I took the time to tear apart a R3 and check your traces and make a few of my own.
http://www.robotroom.com/PWM/VariableDutyCycleSchematic.gif
U6 pin no. Logic
Forward
2 low 3 high 1 low
5 low 6 low 4 high
8 high 9 low 10 low
11 low 12 low 13 high
Reverse
2 low 3 low 1 high
5 low 6 high 4 low
8 low 9 low 10 high
11 high 12 low 13 low
PWM SOURCE THUS FAR
Postby erika » June 10th, 2016, 4:38 am
I want to thank you all for the really useful information.
I was able to "Frankenstein "a 650 using old 400 series parts.
We had a left wheel failure that ended up being from a failed H-bridge. Using your schematics, I was able to desolder and replace the components. Unfortunately, some of the solder pad and conductive tracing between components had exploded, but your diagrams helped me rig the connections back into working order.
Let me add that I am visiting my in-laws in Ukraine, and the possibility of getting a replacement board was nearly impossible!
Thanks again!
erika
Postby BR549 » June 10th, 2016, 9:03 pm
I know this is for the 700 series but want to put it here because I searched a long time to find it in 770 right wheel resistance with power. Thanks guys for all the work making it easy for a beginner.
BR549
Postby 170watt » July 11th, 2017, 1:13 pm
Hello everyone,
I am trying to repair a Roomba 552, but I got stuck. I hope someone knowledgeable could help me.
The original symptom: when battery inserted, the left wheel spun by itself a few seconds. When turned on, Roomba circled counterclockwise. Left wheel felt more sluggish (rotated by hand).
What I did: Transistors Q83 (B772) and Q68 (D882) were replaced (both were shorted). After replacement, the wheel no longer spun by itself, but Roomba kept turning counterclockwise.
I also replaced B772/D882 pair (one set with heatsink that rotate the brushes). Both were shorted. Not sure how these 2 were related, but the symptom persisted (Roomba circled counterclockwise)
I also replaced U4 (74HC02), because the pins showed different 0 or 5V readings (compared with U6 from the right wheel). After replacement, pin 8 continues to show low (0) instead of 5V (by comparison with U6 on the right side). Pin 8 is connected directly with pin 118 from U28 (MCU). The remaining 13 pin voltages are the same. Note that I made the measurements with battery in, but Roomba not started.
I also noticed that the collectors of the power transistor pairs from the H-bridge from left wheel showed 1.3V lower than those from the R wheel. The base and emitter are the same.
What else I did: I replaced transistors Q72, 73, 87, 88 although all were good, of course to no avail. There is also a nearby 8V voltage regulator U27 that shows voltage right on target (7.9V). The other resistors and diodes that are showed on schematic (left counterpart) were verified, but all seemed OK.
Any idea what else I should check? Is it possible that the MCU itself has issues? How can one explain that both H-bridges (left wheel plus brushes) were affected, unless someone spilled water on the board, etc I can’t figure out how these two are connected.
170watt
Postby a1robotrepair » July 11th, 2017, 6:19 pm
Best way to trouble shoot is to run the BIT 13 left forward and 15 reverse.
Change the wheel connector no. to 2=5 and 1=6 in dwg.
Is the bot running the left wheel in reverse always?
Pin 8 fwd/rev bit low-rev high-fwd. shorted to low or MCU fault.
Not Running either way.
Check enable bit low, pins 5 and 9. Common to all PWMs @ U5-5.
Pin 5 on wheel connector near VBAT, check 5 to 6, not there, 5 to GND, not there, forward PNP emmiter @ VBAT. NOR gate pins 11,12 both low, 12 will have PWM input.
Postby 170watt » July 11th, 2017, 7:53 pm
@a1robotrepair
Thanks for your feedback.
I can confirm the left wheel does not run either way.
Unfortunately you’ve lost me. I have some self-thought background in (analog only) electronics, but no experience with repairing Roombas whatsoever (it’s the first time I am trying to make repairs on the Roomba PCB, and I wouldn’t have even tempted, without this post). Not having the schematics (besides what is published on this post) doesn’t help either.
So here’s (some of) what I don’t get:
- BIT = built in test?
- about the wheel connector – this is soldered on the PCB, how I can change the wheel connector pin number; also, the soldered pins are not numbered?! I definitely don’t understand that part. Or this refers to the wheel module itself (and not the main PCB?)
- Under Not Running either way - Check enable bit low, pins 5 and 9 - on what? U4?
- Pin 5 on wheel connector near VBAT – again puzzled, not sure what you are referring to, as connector soldered pins are not numbered?
I would appreciate if you elaborate a bit; you must have assumed I am familiar with roombas repair in general, but not so, unfortunately. Is there another thread(s) I can check, referring to similar aspects?
Again, thanks for your help, and I hope you give me some guidance.
170watt
Postby TechGuy » July 11th, 2017, 8:35 pm
I used a1robotrepair post in the following thread to repair R3 H-Bridges.
viewtopic.php?f=1&t=19065&hilit=+bridge
@a1robotrepair, left wheel H-Bridge uses connector pin 1 and 2 - not pin 5 and 6.
BTW, all H-Bridges(the left & the right wheels and the CHM) use connector pin 1 and 2.
Postby 170watt » July 11th, 2017, 9:53 pm
Thank you, TechGuy.
It seems there is a lot to go through, which is a good thing. I have just started delving into this stuff, all new for me, so I will need some time to digest all of that, and I'll report back later.
170watt
Postby 170watt » July 12th, 2017, 7:01 am
One specific question; there have been a few references to pin (whatever) number of the wheel or brush connector. How are these numbered, I don’t see any pin numbering on the main board for neither one.
170watt
Postby TechGuy » July 12th, 2017, 12:44 pm
Left wheel connector pin 1 & 2.
Left wheel connector.JPG (17.92 KiB) Viewed 2333 times
Postby a1robotrepair » July 12th, 2017, 2:20 pm
I now see the mark, you are correct Canadian Hero! I now need to correct the 800 series wheel dwg.
On the bottom side of the board you will see a round mark indicating pin 1 of the female wheel connector. The 2 parallel corresponding solder connections are your test points. I had the CHM connector discussion with someone else who convinced me that they were actually 5 & 6, she should have been a politician.
Postby 170watt » July 12th, 2017, 3:29 pm
Hi TechGuy, thanks for your input.
I think I am on to something. I noticed that there is no continuity between the collector of the NPN/PNP transistors I replaced (Q83 and Q68) and the other collector pair, and also neither of resistor 249, 250 (those bigger SMDs marked with 0, that I assume are the left counterpart of R241/242) or pin 1 or 2 of the left motor connector. So this begs the question: is there anything else between the collector of this transistors and the aforementioned components? Could be a trace problem? I could just try to solder a jumper between the collector to one of the resistors (I have to figure out which one, it should be the one that connects directly to the collector of Q83/68, and I also have to figure out what side of it).
By the way, the resistors are measuring OK (around 0.1 ohm or so, I don't have a precise multimeter).
==== Update: just found out that an SMD resistor with a marking of 0, 00, 000 or 0000 is a jumper (a zero-ohm link). So these 2 resistors I mentioned above are just jumpers? Anyway, question still remains the same.
170watt
Postby TechGuy » July 12th, 2017, 6:51 pm
I think that those zero ohm resistors act as fuse when too much current is going through the motor.
According to the above a1robotrepair diagram, there is only the 0 ohm resistor between the collectors and the motor. The R249 is connected to pin 1. The R250 is connected to pin2
Next
Users browsing this forum: 911medic, FlyingPolarBear, im1kissfan, KeldBroe, leonicholson, Miles267, someoneclever, sshephard, teokakav, vic7767 and 371 guests
