And did all that checking include dismantling cliff-sensor assemblies down where you get inside the clear plastic enclosures to wipe out all accumulated dust (that might be interfering with sensor ops)?barry1602 wrote:...Now obviously I have done all the usual checks etc to confirm that the fault is actually on the PCB and not on the cliff sensors ...
All right then. I suggest using your O-scope to probe the base pin of Q56 (a bottom mounted S8050, NPN xstr in TO-92 case) to verify pulsed wave train activity. Reference the measurement to "GND". Measure to base and collector solder pads on top side of PCB (to keep the task easy).barry1602 wrote:I have done extensive testing on this to confirm that it is the Pcb at fault and not the actual sensors. ...
Well !! That's a horse of a different color!barry1602 wrote:...Also what I forgot to put in my original post is that if I do the BIT procedure, the cliff sensors test out ok. ...
By ascribing faulty Roomba operation to a specific cliff-sensor module's detected signal you rule out everything except for how that signal is treated on its way to the MCU, or within the MCU.barry1602 wrote:Ok so a further update... - basically I am finding that the left inner cliff sensor is showing a constant cliff (again I know this to be a PCB fault and not a faulty cliff sensor) but the fault does come and go. ...
You have had more than a month to read this thread and, by doing so, learn one answer to your question.matofill wrote:... it is 100% problem on PCB board series 500, so which elements at board can be responsible for that fault ?
Users browsing this forum: TechGuy and 133 guests
