Can I fill scooba after cleaning before next cycle.
Postby tdrakeksu » December 7th, 2012, 8:18 pm
Is it ok, after scooba is done cleaning. To clean it out, filters etc, then put in new cleaning fluid and water, and set it to charge. So the next day, I can just hit start?
So I guess the question is, is leaving the clean tank, full of water and cleaning solution, ok for long periods of time?
Thanks!
tdrakeksu
Re: Can I fill scooba after cleaning before next cycle.
Postby vic7767 » December 7th, 2012, 9:18 pm
The Scooba cleans by using liquid that is gravity fed from the clean tank. There is no on/off valve, the liquid is always present if the tank is in place. The seal is nothing more than neoprene and plastic. You may not have an issue on a new Scooba but there is no way to determine when the seal may be compromised so it is safer to fill the tank when you are ready to run a cleaning session.
Users browsing this forum: Azerial, TechGuy, vic7767 and 107 guests
