new roomba 770 stuck on error 6
Postby djdark » December 24th, 2012, 4:56 pm
Hi, I have purchased two days ago a second hand roomba 770, in perfect conditions,like it was used very few times.
I don't know if it is full charged, but I try to use it, but every time i push clean he tell me to move it to another location. I have read lots of solution, the tin foil, the white paper trick, but nothing works. I have checked with my camera phone if the ir sensors works... and 2 of them are off. So I would like to know, if I dissasemble the roomba and take the sensors off detaching the cables of the sensors from the motherboard, it should work without them?
oh and I don't have any stairs. Thanks a lot for helping me! Ivan M.
djdark
Re: new roomba 770 stuck on error 6
Postby vic7767 » December 24th, 2012, 5:36 pm
Removing the wiring harness that routes the cliff sensors from the connector on the PCAB (Printed Circuit Assembly Board) will cause the MCU (Micro Controller Unit) to continue reporting a cliff sensor error 6. The only resolution will be to discover what caused two of the sensors to fail and repair them.
Postby djdark » December 26th, 2012, 6:22 am
Ok, thanks for the reply,I live in Switzerland and I speak french, so my english is not that good. I will look over more post before opening the roomba,that's a shame I wanted it so much... Now when you say "repair them" I can put a new diode sensor isn't? that would be a easy way, because if not something is wrong with the PCAB.
djdark
Postby vic7767 » December 26th, 2012, 11:25 am
Yes, you are correct. If replacing the IR sensor pair does not fix the error 6, then it will be the PCAB.
Users browsing this forum: fuzzydunlop, instrukcije, johnnyh, Miles267, Rar9, symbol and 346 guests
