AUS Roomba 650 vacuum/AeroVac bin is always on
Postby StygianBeast » December 27th, 2012, 4:29 pm
Hi all,
Just opened a brand new Roomba 650 and upon removing the battery tab the vacuum/AeroVav came on.
The vacuum is on when the Roomba is on, when the Roomba is off, after docking, while charging, all the time. The vacuum only stops if I remove the battery or the dust tray.
I did a software reset using the dock/spot buttons. I removed the battery several times. All to no avail.
Whenever the battery is connected there's a current on the AeroVav contacts.
Has anyone had this problem before?
StygianBeast
Re: AUS Roomba 650 vacuum/AeroVac bin is always on
Postby vic7767 » December 27th, 2012, 6:15 pm
There is a driver transistor that has failed on the main mobo of your Roomba. If under warranty return it for a replacement.
Postby StygianBeast » December 27th, 2012, 7:21 pm
Thanks vic7767, that makes sense.
It'll take forever for the replacement to get here, I might replace the transistor myself...
StygianBeast
Users browsing this forum: yohai and 102 guests
