vic7767 wrote:You are not doing anything wrong. What must be considered is the capacity of the installed battery. Once the battery voltage reaches a predetermined value (12 vdc) the docking program is activated.
vic7767 wrote:Also I have not read of anyone using more than 3 LH/VWs with any success. Since each accessory will contain the Roomba for about 25 to 30 minutes the (stock) battery won't last for more than about 80 to 90 minutes. So using 4 to 5 LH/VWs will require a battery capacity of 120 to 150 minutes.
