Roomba 4xxx - Separate Gearbox from Main Brush Motor
Postby keith6226 » December 31st, 2012, 6:54 pm
Hello all,
I purchased a replacement brush motor to fix a 'not spinning under load' issue. I did not realize, however, that it would not include the attached gearbox. The existing gearbox seems very securely attached though, possibly glued - is there a good way to separate these two?
Thanks,
keith
keith6226
Re: Roomba 4xxx - Separate Gearbox from Main Brush Motor
Postby vic7767 » December 31st, 2012, 7:17 pm
Keith, there is a small plastic semi circular part that hides the two screws between the brush motor and the gear reduction gear box. Lift that part out using a small screwdriver or pocket knife blade.
Postby keith6226 » January 1st, 2013, 3:59 am
Thanks Vic,
That did the trick. There was still a bit of grease slathered in there so I did not even notice there was a seam there.
After taking it completely apart though, I noticed that one of the gears had a couple of broken teeth. I am thinking that this is the more likely cause of failure. Looks like I should have bought the gearbox and not the motor, but live and learn.
Thanks again,
keith
keith6226
Users browsing this forum: BravoRomeo, neat99, ohiyo777, TechGuy, vic7767 and 91 guests
