Bumper sensor not broke?
Postby jwalter » January 8th, 2013, 8:34 am
I have a 5 series that is doing the dance.
I ran the diagnostics according to AVIs page.
When testing the bumpers, the left side functions as normal. The right side has no response.
I wanted to check to see if there are any other test to determine if the problem may not actually be the sensor. All of the test I have found are to determine if the sensor if stuck.
Anyway to simply bypass it all together as a test?
Jason
jwalter
Re: Bumper sensor not broke?
Postby vic7767 » January 8th, 2013, 11:40 am
Your Roomba is suffering a very common fault. The bumper sensor is composed of an IR emitter and receiver that is located inside of a plastic case behind the front bumper. The emitter is failing to transmit the IR signal that causes the MCU to react to a pushed bumper. The solution is to replace the IR pair in both bumper sensors.
Postby jwalter » January 8th, 2013, 12:26 pm
Great thanks. I figured that but wanted to do a quick check before diving into this repair.
jwalter
Users browsing this forum: vic7767 and 145 guests
