Series 5xx WCC on 780?
Postby bepe » March 4th, 2013, 5:48 am
Hi, i heard, that's possible to pair a Series 5xx Wireless Command Center on a 780 with following limitation:
the Clock/Schedule things do not work.
I have tried to pair a 581 WCC on my 780 but it doesn't work.
Is there somewhere a description to do this?
bepe
Re: Series 5xx WCC on 780?
Postby matofill » March 4th, 2013, 10:11 am
It must go without any problems, the only problems is, that you must check instruction for Roomba 500 and seen, how to paired Comand center with 500 Roomba s , and then to do the same on your 700 Roomba s. Your Comand center can be paired only to one Roomba at the same time !!! 8)
matofill
Postby bepe » March 4th, 2013, 10:19 am
I tried it with the instruction for 500 series but it doesn't work.
The 780 switches on during pair and after that nothing happens...
I tried this one:
■Make sure Roomba's battery is fully charged.
■Unplug the Battery Charger or remove Roomba from its Home Base.
■Install three AA batteries into the Wireless Command Center.
■Hold down the left drive button while installing the fourth battery.
■Continue holding the left drive button for 3 seconds or until the days of the week lights flash in a sequence from Right to Left (Saturday to Sunday).
■Install the battery door, and place the Wireless Command Center on top of Roomba.
■Press and hold the DAY and MINUTE buttons on the Wireless Command Center for 2 seconds. The lights on the Wireless Command Center will flash to indicate the pairing has completed, and Roomba will make a two-tone beep.
■When the Wireless Command Center is powered on from now on, the lights will sequence from Left to Right until Roomba is under control.
bepe
Postby vic7767 » March 4th, 2013, 11:46 am
The 500 WCC accessory will work with the 780 Roomba but it cannot be used to set the time or schedule. The Clean, Spot, and Dock buttons will work as well as the Forward, Left and Right buttons.
Distance is a factor when attempting to pair the WCC with the 780. To pair, place the WCC on top of the 780. With the Leds flashing from right to left on the WCC the 780 will turn on and light the Clean button. At that point you can lift the WCC away from the 780 and use the movement buttons as well as the Clean, Spot, and Dock.
Postby bepe » March 4th, 2013, 2:59 pm
Can you explain the whole procedure please?
I don't get it to work...
bepe
Postby vic7767 » March 4th, 2013, 3:53 pm
With the WCC flashing its LEDs from Right to Left, place it on top of the 780 Roomba. The Roombas Clean LED will turn on after a few seconds and then the WCC LEDs will stop flashing and its Clean, Spot, and Dock LEDs will turn on. Then you can use the direction buttons to send it where you want it to go or press the Clean button to send on a cleaning run or press the Spot button to spot clean or press the Dock button to send to the dock.
Postby bepe » March 4th, 2013, 5:47 pm
The only thing that works is:
If the Roomba is switched off, i can switch it on with any button, but after that i get no additional funktion...
bepe
Postby vic7767 » March 4th, 2013, 6:00 pm
There is evidently something else that is causing you difficulty. Are the batteries in the WCC new ?
Postby bepe » March 6th, 2013, 9:10 am
Hmm...
i tried it again with brand new batteries (1,55 V each) but it doesn't work :evil:
I saw the same in a german robot forum from an other 780 User which has two 780s, one 780 works with two different WCCs, the other 780 with none.
Perhaps there is a firmware change for newer ones?
Or irobot changed the pairing procedure?
bepe
Postby 3kgt » August 4th, 2013, 5:10 pm
Have same problem!
Just bought a new 780.. trying to pair with WCC...dosent work..
while trying to pair it the 780 turns on, thats all the connection they seem to get!
Will contact irobot and see.. if any one dose find any thing new plz do inform
Love robot vacums :)
Today: Neato Botvac 70E
Tested: Neato XV-14,15, Signature pro & Irobot 521,581, 630,650,780 + 2 Samsung modells + XV-25 + Scooba 230
3kgt
Postby vic7767 » August 4th, 2013, 5:50 pm
Lets remember, the 500 accessories are not advertised to work with the 700 model Roombas. There is a new WCC accessory for the 700 Roombas.
Postby 3kgt » August 5th, 2013, 10:22 am
vic7767 wrote:Lets remember, the 500 accessories are not advertised to work with the 700 model Roombas. There is a new WCC accessory for the 700 Roombas.
Sure, but i did send an email to Irobot before i bought the 780 wich they confirmed that it will work with it.
Now i did send a nother mail last night wich i have not yet recived an answer to.
3kgt
Postby casino187 » August 7th, 2014, 2:03 pm
I have a Wireless Command Center for a 790. as soon as I turn it on, the lights flash from left to right. which I think means it is paired with the 790 that it was packaged with. I want to reset this thing to pair it with a different roomba, but all instructions say the lights need to go from right to left. I can not figure out how to get this to happen.
any ideas? I tried the hold left arrow, press clean and release and continue holding left arrow until it works. well, that didn't work.
Thanks guys,
Brandon
Almost every Roomba and Scooba part is available in my ebay shop.
www.casino187.com
casino187
Postby casino187 » August 7th, 2014, 2:04 pm
I may have just figured it out! i did the reset again, but I made sure no lights were flashing when I did this procedure. it automatically turns off after a minute or so. they should put this in the instructions
www.casino187.com
casino187
Users browsing this forum: Per L, teokakav and 284 guests
