Scooba 230 won't move from the spot
Postby piokrza » May 5th, 2014, 4:08 am
It's almost new. Water pump and vacuum impeller are working fine but it won't move from the spot. What could be wrong?
piokrza
Re: Scooba 230 won't move from the spot
Postby third_deg » May 5th, 2014, 1:02 pm
Clean tank empty sensor is best guess
I can't imagine both wheel drives failing at the same time
third_deg
Postby vic7767 » May 5th, 2014, 1:36 pm
Don't forget, you can also run the Built in tests, only issue is you won't be able to monitor the output results.
Postby piokrza » May 5th, 2014, 2:35 pm
third_deg wrote:Clean tank empty sensor is best guess
How can I do that?
piokrza
Postby vic7767 » May 5th, 2014, 3:55 pm
piokrza wrote:How can I do that?
Try using some distilled white vinegar mixed with water and 1/2 fill the clean bladder. Then shake very well. The shaking and vinegar may clean the liquid sensor in the clean tank. To test just press the Clean button after the shaking. If the 230 starts moving then you have resolved the issue if it was the clean tank sensor.
Postby Roombascoobatastic » May 7th, 2014, 9:40 am
Not sure if this helps but on my 230s, the rubber tube in the peri-pump gets stuck shut and the unit fails to operate. I have to take out the tube and roll it between my fingers to get it working again.
Sincerely,
Rick
Roombascoobatastic
Magazine Editor
Postby jigalongaccountant » March 20th, 2017, 10:06 am
Mine just sits there and the red triangle error comes immediately on, Pulling my hair out
jigalongaccountant
Users browsing this forum: 911medic, BCCISProf, fuzzydunlop, jdong, jtheruler791, Metalworker, Miles267, off-road-biker, RockinRay, vic7767 and 328 guests
