Scooba 450 stopping too soon
Postby edcba » August 13th, 2016, 11:45 pm
According to the manual Scooba 450, in the default state for a large room, is meant to operate for about 45 minutes. Our Scooba however stops in about 25 minutes and the Clean water tank seems to be only half empty. Is this a problem with the Clean Tank sensor and, if so, how can it be fixed?
edcba
Re: Scooba 450 stopping too soon
Postby a1robotrepair » August 14th, 2016, 6:34 am
Need more information.
Will it start to clean again if you restart?
Fill tank and restart?
Needs to charge and restart?
Postby vic7767 » August 14th, 2016, 9:49 am
edcba wrote:According to the manual Scooba 450, in the default state for a large room, is meant to operate for about 45 minutes
What size is the area your 450 is cleaning ?
Postby edcba » August 14th, 2016, 7:07 pm
Size about 2 metres by 10 metres. Scooba does not start again after stopping--the message says it has finished.
edcba
Postby vic7767 » August 14th, 2016, 7:40 pm
edcba Is your 450 covered under a warranty ? If so it will be best to request a replacement or refund.
Postby Botty » January 24th, 2019, 6:36 pm
I’ve just started having this problem. Everything works completely normally except the cycle finishes after 20 mins instead of 40. Did any clues emerge as to why it might be happening?
After it stops its first cycle, I can press clean again without filling the tank and it completes a second 20 minute cycle.
Botty
Postby vic7767 » January 25th, 2019, 3:13 pm
Has the 450 somehow been configured for the smaller room size? Removing and replacing the battery may reset the room size options.
Postby Botty » January 28th, 2019, 7:11 am
vic7767 wrote:Has the 450 somehow been configured for the smaller room size? Removing and replacing the battery may reset the room size options.
good call on the battery, i'll try that, thanks.
yeah the cycles are so precisely 20 minute blocks that it clearly thinks it's cleaning a smaller room, but I hadn't set it to that so I have no idea how or why it's working to the small room setting,
Botty
Postby Botty » February 23rd, 2019, 4:59 pm
Just wanted to say that your solution fixed the problem, thanks Vic
Botty
Postby vic7767 » February 23rd, 2019, 6:19 pm
:cheers:
Users browsing this forum: ASTMedic, BrettS, im1kissfan, jdong, jomo, lanchez, someoneclever, vic7767, Wing Nut and 223 guests
