Roomba 980 and IR remote
Postby misiakufal » September 1st, 2016, 5:34 pm
Hi All,
Accidentally I've discorvered, that despite Roomba 980 does not have IR remote unit included in the set, it does have IR receiver under the hood. Because I don't have an actual IR remote unit, (probably from 700/800 series) I've tested it with RCoid Android app (they have Roomba remote unit definition file on their website) on note4.
It allows you to Clean, SpotCean, ReturnToBase and manual direction control.
Best regards
misiakufal
Re: Roomba 980 and IR remote
Postby a1robotrepair » September 1st, 2016, 5:57 pm
Verified with 500/600/700/800 remote.
Postby RoboCup » September 2nd, 2016, 7:27 pm
Thanks for the info. :o It's nice to know they included that even though it's not noted anywhere that it's compatible with the remote. I guess the thought is that with the app, remote is not needed. But at that price, maybe they should've tossed in the remote!
RoboCup
Postby ps0001 » July 11th, 2018, 9:23 pm
Sorry to resurrect such an old thread, but does anyone have any idea how direction control via an IR remote affects a 9xx's navigation? For instance, if I sent the robot to a particular area from its base using the remote, could it find its way back?
ps0001
Postby vic7767 » July 11th, 2018, 10:20 pm
When using a remote control to guide the 9XX Roomba, the imag ing program is inactive and no maps are being generated. Locating the home base will become a 50/50 attempt and if the home base signature is detected while seeking to dock then it will.
Postby ps0001 » July 11th, 2018, 10:41 pm
Darn... back to the drawing board. I wish they'd open up an API for the 9xx series!
Could you tell me what the dock seeking behavior is like in the 960/980? I'd imagine it's a bit more methodical when trying to find its home than previous models.
ps0001
Postby vic7767 » July 12th, 2018, 7:27 am
Without a map being generated, the 9XX models will behave just like their predecessors.
Postby RTC » August 27th, 2018, 4:04 am
ps0001 wrote:Could you tell me what the dock seeking behavior is like in the 960/980? I'd imagine it's a bit more methodical when trying to find its home than previous models.
All it does is move around until it intersects the beam from the Home Base. then heads for it. If it fails to see the beam in a reasonable time it spins for a while and heads off in a "random" direction to try again. If it succeeds but fails to dock it backs off 3 to 4 feet and makes another docking attempt.
It really needs to be close if it was not doing a normal end of mission return home to succeed. If manually sent home from a random location (e.g. a different room than the Home Base is in) it will almost certainly fail and probably report Error 18.
Users browsing this forum: KeldBroe, lanchez, tre, twistdh and 341 guests
