Roomba Series 700/800 will not turn on
Re: Roomba Series 700/800 will not turn on
Postby a1robotrepair » January 10th, 2017, 11:03 am
No time right now. I feel like this guy.
https://m.youtube.com/watch?v=SdaA1PFyuR8
Postby a1robotrepair » February 9th, 2017, 2:45 pm
870 is in the shop with no response from buttons. Set on Base and goes into refresh charge with CE3 after 9 seconds. Term software reads mV 111, mA 0, tenths-deg-C 23.1, mA 0, state 3
charging-error 3
5V reg available @ L1.
6.4V supply to U4 pin 4 available while on base.
U4 supplys the reference for battery voltage, current and temperature to the MCU.
Simular to R3 U8 but not exact.
Time to trace U4.
First rule of troubleshooting, fix known problems first.
No charging current on base, looking for increase in bat V, check U4 battery reference first, U4 A2 pins 5,6 & 7.
20170209 16:00
WELL, pin 5 is tied to system return.
It appears 700/800 process the VBAT sense differently than R3. Thermistor sense A3 and Current Sense A4, A1 are processed thru U4.
20170209 16:40
Shot in the dark, looked @ R3 U8 sketch, found R207, 475K. Visual trace leads to VBAT, no continuity.
Last edited by a1robotrepair on February 10th, 2017, 6:19 pm, edited 1 time in total.
Postby a1robotrepair » February 9th, 2017, 7:17 pm
https://m.youtube.com/watch?v=g0qTOLBhlVs
Installed jumper, happy start battery 5 note song :dance:
No clean or other button response. :violin:
Placed on base, CE3 after 9sec.
mV 15502, that part is fixed, mA 0 tenths-deg-C 252 mAH 2696 state 5
More investigating needed.
The thru board copper is blown from VBAT to R207. Expect something similar, maybe in same area.
Last edited by a1robotrepair on April 10th, 2018, 7:37 pm, edited 2 times in total.
Postby a1robotrepair » February 10th, 2017, 3:34 pm
Didn't find obvious blown trace.
Traced UI board SW1, Clean button.
UI J1-3 to R9 (103;10K) SW1+
SW1- to J1-4
To main board.
J13-3 to D47-C visual trace, no conductivity. Another Jumper. Same area blown trace.
Turns on with buttons :dance:
Charging error 3. :violin: expected. Q17 not turning on. Another blown trace?
Postby a1robotrepair » February 11th, 2017, 9:08 pm
a couple of drawings to help with troubleshooting
Last edited by a1robotrepair on February 23rd, 2017, 7:37 pm, edited 6 times in total.
Postby a1robotrepair » February 11th, 2017, 11:43 pm
Q17 is working fine.
factory-test 12 battery-sensors
(battery-voltage-ok?) mV 552 min 431 max 647 PASS
(baseline-current-ok?) mA -111 min -200 max -80 mV 15363 degrees-C 24 PASS
Q18 is not.
factory-test 25 charger-watchdog
wait-true-for-time (32 ticks): (test-charger-available?)
(int-charging-watchdog-current-ok?) mA 0 min -31 max 31 mV 15585 degrees-C 25 PASS
factory-test 26 ext-charger-recovery
wait-true-for-time (32 ticks): (ext-charger-available?)
(ext-charging-recovery-current-ok?) mA 1143 min 250 max 350 mV 15808 degrees-C 25 FAIL
factory-test 27 ext-charger-on
(ext-charging-current-ok?) mA 1162 min 1000 max 1400 mV 15864 degrees-C 25 PASS
factory-test 28 ext-charger-trickle
(ext-charging-trickle-current-ok?) mA 1154 min 40 max 70 mV 15947 degrees-C 25 FAIL
Q18 full on during recovery and trickle.
Need to check R277, R276, C224, D4, Q21, Q21e to MC.
http://www.mouser.com/ds/2/389/str730fz2-956790.pdf
Postby przemo33 » February 14th, 2017, 10:19 am
Hello,
In my case ,on PCA at the connection of L1 and C287 is 1,6V (instead 5V) :(
Regards.
przemo33
Postby a1robotrepair » February 14th, 2017, 1:35 pm
Updated charging DWG with corrections. The Clean Button along with the robot being placed on the charger gives a signal to the Voltage Converter U3 on pin 3. Will be investigating SMPS soon. 700 without button responses. Can turn on with term software and buttons work and bot acts normal, starts cleans docks schedules,...normally.
Postby a1robotrepair » February 17th, 2017, 1:54 pm
700/800 5V Reg
DWG added earlier to this Post page.
LM3489x Hysteretic PFET Buck Controller With Enable Pin
http://www.ti.com/lit/ds/symlink/lm3489.pdf
przemo33, First thing I would check from here is Q15 collector for 3.3V. The top DWG.
Remove Battery and continuity check pin 2 and 6 to SysRtn pin 8 to
d47.
Last edited by a1robotrepair on February 25th, 2017, 2:07 pm, edited 1 time in total.
Postby przemo33 » February 21st, 2017, 3:04 am
Hello,
Voltage between Q15c and VBAT (+) is 12.8V
On U3:
Continuity between Pin 2 and Pin 6 to SYS_RTN - OK
Continuity between Pin 8 and D47 - OK
Regards
przemo33
Postby a1robotrepair » February 22nd, 2017, 12:11 am
przemo33 wrote:Hello,
All V readings to SysRtn.
I was looking for 3.5V to sysrtn for a fully charged battery. -12.8 to VBAT is reasonable for a fully charged battery.
The junction of R174 & R175 that feeds the feedback pin, FB, pin4 U3, should read 1.24V.
I get a 13.7V reading on the Gate, pin3 of Q7. Robot off, battery 16V.
Lastly, I sense pin 1 should be 5.1V and R78 to pin 5 U3 should be 140mV less than D47 to sysrtn.
Check D2.
Last edited by a1robotrepair on February 22nd, 2017, 1:40 am, edited 2 times in total.
Postby a1robotrepair » February 22nd, 2017, 12:46 am
My inop 870 is now charging. While testing I must have Jared whatever was causing a short circuit to correct itself.
Postby przemo33 » February 23rd, 2017, 3:17 am
Hello,
a1robotrepair :cheers:
Thank you very much, one "alive" :)
There was no continuity between pin 1 U3 and Q7d
Roomba runs OK !!!
Only one problem is - No sound is silence in speaker (the speaker is good)
Regards
przemo33
Postby a1robotrepair » February 24th, 2017, 10:12 am
Cool beans.
With your and my posts, one can surmise what the V readings on the Buck Controller are during Current limit conditions.
The blown traces on my 800 main board both occurred next to the VBAT on the bottom of the board, indicating that that area got very hot.
I suspect a problem @ Q19 was causing my CE3. I cleaned and traced it before reconnecting to the base. It charged normally afterward.
Postby tilk » February 5th, 2018, 4:53 pm
Hello,
I have a Roomba 700 motherboard which does not turn on. The +5V rail is stuck at 2V. The waveforms measured on Q7 and U3 indicate that the converter is in overcurrent mode; the 9us pause between pulses is clearly visible. When I disable the overcurrent protection by shorting the ADJ pin of U3 to ground, the converter starts up normally and generates stable 5V output, then the motherboard lights up.
I tried to test why it's entering the overcurrent mode, but I've noticed something weird: when Q7 is turned on, the voltage at the drain is measured 0.4V higher than at the source, which definitely should not happen. (When it's turned off, the voltage is as expected: goes negative, and when the inductor current reaches zero, goes to the 2V voltage at the output of the converter.) Is my scope playing tricks on me?
Here is what the scope (Rigol DS1052E) showed me. Blue is source, yellow is drain.
tilk
Postby mfortuna » February 6th, 2018, 7:10 am
I've seen that happen due to to stored charge in a capacitor but the voltage should have decayed over time. Maybe 200ns wasn't enough. One thing to try is supply 5V with a bench supply and see what the current is. Or look for smoke ;)
Postby tilk » February 11th, 2018, 12:01 pm
Current was fine. I've disabled the overcurrent protection by soldering a wire from ADJ to ground and assembled the Roomba back. Seems to work fine, for now ;)
Edit: Aaaaand it died.
tilk
Postby tilk » March 21st, 2018, 5:25 pm
For posterity: I have replaced the LM3489 and the pass transistor, and the crazy waveform is not there anymore and the Roomba works fine.
tilk
Postby a1robotrepair » March 21st, 2018, 5:42 pm
tilk wrote:For posterity: I have replaced the LM3489 and the pass transistor, and the crazy waveform is not there anymore and the Roomba works fine.
Pass transistor ? Which transistor?
Users browsing this forum: Botty, BrettS, fufu, hage.ny, johnnyh, KeldBroe, Markrose, someoneclever, spectrum1c, vic7767 and 362 guests
