Roomba 530 charging err3
Postby tritin44 » November 3rd, 2016, 6:40 pm
Hello, I recently got a secondhand roomba and whenever I plug in the charger it gives the charging error 3. It's original battery was completely dead, no tone when it was put in, so I bought a new one. The roomba makes a happy tone when it is put in and will clean if I push the button, however it still will not charge the new battery. I checked the voltage on the cord and it was approximately 22.5 V and the battery was reading around 14~V. There was a small amount of corrosion on the contacts but I cleaned those with isopropyl alcohol and a Q-tip. The only thing out of the ordinary is the 2 shiny bits at the top of the picture dont match
here's a better picture of the battery contacts
this looked questionable to me
tritin44
Re: Roomba 530 charging err3
Postby TechGuy » November 3rd, 2016, 7:32 pm
Did you pull the spring contacts,in the battery well, up a bit?
You should clean the battery corrosion on the spring contact with fine sand paper.
The second photo is not the battery contact.
Postby tritin44 » November 4th, 2016, 3:30 pm
Sorry I meant the back of the contacts
Here are the contacts
tritin44
Postby tritin44 » November 4th, 2016, 9:14 pm
I pulled on the contacts and still the same result. Another thing I noticed is that err3 happens if I plug in the roomba without a battery
tritin44
Postby TechGuy » November 4th, 2016, 9:51 pm
One of the big spring contact in the battery well does not look clean to me.
What is the resistance value between two small terminals on your new battery?
A client of mine purchased a non-iRobot battery with the two small terminals shorted. When I open the battery and discovered that the thermistor leads were shorted together.
Postby mfortuna » November 5th, 2016, 9:51 am
The shiny bits are fine. The three pads are soldered and that is important.
Postby tritin44 » November 7th, 2016, 11:27 pm
sorry for the slow responses, I decided to ask this right before 3 midterms but I will check the thermistors tomorrow and get back to you
thank you for the confirmation on the shiny bits as well mfortuna
tritin44
Postby tritin44 » November 8th, 2016, 8:27 pm
No resistance between the thermistor so it's bad?
tritin44
Postby vic7767 » November 8th, 2016, 10:28 pm
Yes, that would be bad. You should see a reading around 10 kOhm.
Postby TechGuy » November 9th, 2016, 1:46 am
0 ohm = high temperature = thermistor is no good OR the thermistor leads are shorted together
10k ohm = around room temperature
Roomba monitors the battery temperature while charging. It will stop charging when it finds out that the battery is hot.
Postby tritin44 » November 9th, 2016, 6:13 pm
Alright I will do a return, for reference it is a Powerextra brand battery
Update: I got a replacement battery from the company and I am experiencing the same err3 as before. I was fiddling with the battery while it was plugged in and temporarily got a charging error 2.
I will test the thermistor on this one just to be sure
tritin44
Postby tritin44 » November 15th, 2016, 9:18 pm
New Info
I just tested the thermistor on the new battery and they are at 10k at RT. Also the battery voltage is 14-15V so from what I have seen this is a perfectly good battery. I still have the err3 triggering sadly
tritin44
Postby TechGuy » November 16th, 2016, 12:38 am
The no load Roomba battery voltage should be around 16v - 17v.
Charge it again. If you still get 14v-15v, something is wrong with your new battery.
Postby a1robotrepair » November 16th, 2016, 7:38 am
viewtopic.php?f=1&t=17151
Advanced Search, +charging +error +3 by Author Gordon
Cleaning your main PCA will usually cure the problem.
Postby tritin44 » November 25th, 2016, 1:46 am
TechGuy-recharged battery and all is well
a1robotrepair- I will look more into that this weekend hopefully
another note-today I plugged it in and the err3 popped up again, but after a few seconds the blinking red light ceased and it was solid green, is this normal during an error or is it good to charge off of?
tritin44
Postby tritin44 » November 25th, 2016, 10:12 pm
Final update
I solved the error. It turns out there was a tiny amount of corrosion on the components below the battery terminals. So little it gave a greenish tint I barely noticed but now it's happily charging in the corner
tritin44
Postby Honestlai » January 10th, 2017, 4:44 am
I'm having the exact same problem you were. Where on the board or contacts did you clean?
Thanks,
-Matt
Honestlai
Postby Honestlai » January 11th, 2017, 4:57 am
I figured it out... another post mentioning taking a toothbrush w/ cleaner to the corroded area and then a heat gun. After I did both, the issue has gone away! I am now the proud owner of a Roomba! :D
Honestlai
Postby off-road-biker » January 11th, 2017, 9:10 am
Honestlai wrote:I'm having the exact same problem you were. Where on the board or contacts did you clean?
Honestlai wrote:I figured it out... another post mentioning taking a toothbrush w/ cleaner to the corroded area and then a heat gun. After I did both, the issue has gone away! I am now the proud owner of a Roomba! :D
Matt, would you please show on a pic where to clean and post a link to that post?! Thanks!
Roomba 560 with 700 ECHM (grey) and modded original vac bin (R3)
off-road-biker
Postby cherokee180c » January 21st, 2017, 12:16 pm
I am having a similar problem, but using the lithium Power Inc replacement battery. Everything was working OK until I took apart to clean. I can't do the normal battery reset procedure, as I can't get any power to the Roomba to hold down the spot and dock buttons to do the battery reset. I think the lithium battery might be in sleep mode, but the procedure to wake up is the normal battery reset. It acts like it is charging fine with orange pulsing mode until I get red error and clean light flashing. I am pretty sure it has nothing to do with dock or power supply as I am having the same error on two different dock/power supplies as well as plugged in directly. Any advice to try?
cherokee180c
Users browsing this forum: 911medic, BCCISProf, fuzzydunlop, jdong, jtheruler791, Metalworker, Miles267, off-road-biker, RockinRay, vic7767 and 328 guests
