Scooba 390 start and stop after few centimeters...
Postby junioroskovic » November 12th, 2016, 7:44 am
When I start my Scooba, the pump works well, then it run and stop after some centimeters, then start again, then stop... etc 5 times.
Then stop with 1 beep.
No default light status.
I clean it several times, the whells are not stuck, I check the battery which is ok.
I run the Scoobat built-in-test, and all the test pass successfull...
I posted a video of the behaviour here: https://youtu.be/pyiru-orsEI
I contact IRobot support, but they said that my Scooba is dead...
Have you ever seem this problem?
(I'm french, so, sorry for the bad English).
Thanks for your help.
junioroskovic
Re: Scooba 390 start and stop after few centimeters...
Postby vic7767 » November 12th, 2016, 10:13 am
Your you tube video is set to "Private" and cannot be seen.
Postby junioroskovic » November 13th, 2016, 5:05 am
Sorry, the video is now public.
junioroskovic
Postby vic7767 » November 13th, 2016, 1:49 pm
Did the side wheel drop sensor tests pass (BiTs 5)
Postby junioroskovic » November 17th, 2016, 5:18 am
Yes side wheek drop pass left and right.
junioroskovic
Postby vic7767 » November 17th, 2016, 10:21 am
It may be possible that one of the motors that start up at the beginning is using too much current. It will be difficult to locate using the BiTs program. Possibly monitoring the SCI output during the BiTs may provide additional information. You may consider main board replacement.
Postby junioroskovic » November 23rd, 2016, 2:41 pm
ok, thanks, I will check how much cost a main board.
junioroskovic
Postby vic7767 » November 23rd, 2016, 3:18 pm
ebay has them for $25 to $45 plus shipping.
Postby junioroskovic » November 24th, 2016, 1:35 pm
thanks for this info.
junioroskovic
Postby lanbinder » July 31st, 2017, 3:01 pm
Hi ! I have the same problem!
Could you solve it?
lanbinder
Users browsing this forum: a1robotrepair, Aniseedvan, KeldBroe, Metalworker, Miles267, mobzd, someoneclever, symbol, vic7767 and 413 guests
