Roomba 980 error 17
Roomba 980 error 17
Postby Transammatt » March 13th, 2017, 12:09 pm
Love my roomba but the error 17 is killing me.
Roomba will clean for up to two hours it's almost done and returns to base for more juice.
After the recharge it goes back out and within 20-30 min I get the error 17 message.
Anyone having this problem with there 960-980?
I'm thinking with my kids and wife opening and closing the doors it may be confusing the robot?
Maybe at night there is not enough light?
What do you guys think.
Irobot not to concerned that there is a problem. But told me they may send me a new one if it keeps happening.
Matt
Transammatt
Re: Roomba 980 error 17
Postby vic7767 » March 13th, 2017, 12:26 pm
So, is your 980 cleaning only in the dark? at night? Does the err 17 occur in daylight?
Postby Transammatt » March 13th, 2017, 12:53 pm
Yes after dark, I do have some lights on. I read somewhere on here that night light would be enough light so see?
I will run after I go to bed with lights on and see what happens.
Transammatt
Postby vic7767 » March 13th, 2017, 1:02 pm
That is my understanding also. The 980 and 960 should also work in total darkness but without VSLAM enabled. Defaults to earlier Roomba AWARE program. I'm not sure what err 17 actually is associated with. Movement, mechanical, battery ?
Postby Transammatt » March 13th, 2017, 5:13 pm
If Roomba says “Error 17. Please open the iRobot App for help,” it means Roomba cannot complete its cleaning job. Ensure the following:
Ensure there were no changes to the environment during the cleaning cycle (i.e. closed door, moved furniture).
It is possible for Roomba to drive over transitions, such as doorway thresholds, that it cannot drive over again to leave the area. In this case, you may need to use Dual Mode Virtual Wall® Barriers to section off these areas to clean.
Ensure the house has adequate light (daylight or dim lighting is sufficient) for Roomba to navigate. Extremely dark rooms could obscure the iAdapt® localization camera and cause problems with navigation and coverage.
Excessive clutter could contribute to this error. Clear cluttered areas or use Dual Mode Virtual Wall® Barriers to block off problem areas.
Ensure the camera is clear of any dust or debris. Wipe the clear window on the top surface using a microfiber or soft cotton cloth that has been lightly dampened with water or a screen cleaning solution.
Transammatt
Postby opres » October 2nd, 2017, 5:16 pm
I would like to ask you how did you solve your problem as I'm having the similar one.
opres
Postby Weloveourroomba » October 20th, 2017, 1:29 pm
I am having the same problem.
Roomba is clean, cleaned up most of the apartment in the daylight.
Before returning to the base, like one meter in front of the base it will stop and
have the error 17. It’s very annoying.
Does anyone know how to solve this problem?
Weloveourroomba
Postby G-Man71 » November 16th, 2017, 6:11 pm
I have this problem a lot with my Roomba 980. It’ll head back to the charging base and then it’ll stop about 3 or 4 feet from the base and give me an error 17. It doesn’t do this every time, but enough to make it annoying. I’ll probably try to contact iRobot to see if they have any suggestions.
G-Man71
Postby Tjfortuna » December 15th, 2017, 3:05 pm
Yes I’m having the same problem.
Tjfortuna
Postby RonJ103 » January 10th, 2018, 2:16 pm
I just experienced this issue as well. The roomba was sitting a few feet from the dock. Just sitting there for no reason saying "Error 17". Once it was instructed to go to the home dock, it did so without any issues.
RonJ103
Postby DakotaFox » January 16th, 2018, 10:29 am
I get error 17 often too, 3 or 4 times a week. My 980 will get 1 to 4 feet from the base and stop and announce 17. Sometimes it is in the middle of a cleaning job, in the middle of the floor and stops and announces error 17.
DakotaFox
Postby jbaugh » April 11th, 2019, 1:30 pm
Has anyone found a solution to this error 17 problem. My Roomba 980 exhibits the same behavior. I replaced the battery with a new one. This did not help. Roomba stops 2-3 feet from home base completely discharged.
John
jbaugh
Postby RTC » April 11th, 2019, 2:58 pm
I do not recall getting any error 17s in the more than 2 years that I have had my 980. But when I get any "Please open the iRobot App for help" errors all I can do is follow the printed instructions in the manual as I cannot operate a smartphone, so I do not have the App to open for help.
I have had a few times (early on) when the 980 had gotten into a dark room at night and I found it just spinning round and round. No error was reported and turning on a light in the room stopped the spinning and it continued the cycle with no further problems. I now make sure lights are on in all rooms when it cleans at night.
I did find by accident that plugging the Home Base into a UPS causes all sorts of strange often intermittent problems. Including failure to find the Home Base! Always plug either directly into the wall outlet or a surge suppressor, never a UPS or any other type of "power converter"! The manual, in the battery section (I think it s/b in the Home Base section) warns that plugging into a power converter can cause damage to the unit and will void the warranty!
RTC
Users browsing this forum: ASTMedic, BrettS, joanquro, johnnyh, lanchez, mobzd, orion262 and 320 guests
