Slow pulsing orange light and not charging
Postby bebios » March 20th, 2017, 4:26 am
Hi all,
Need some help and hopefully be able to repair my roomba 570 charging issue.
My roomba is having a slow pulsing charging light for a few hours then shows an error 7 charging fault. With the battery removed, the slow pulsing orange light persists.
Anyone knows what are the possible components in the charging circuit have failed?
Thank you all so much.
bebios
Re: Slow pulsing orange light and not charging
Postby Brett » March 20th, 2017, 6:19 am
Postby bebios » March 20th, 2017, 8:40 am
Brett wrote:You need to replace diode D58.
viewtopic.php?f=1&t=17764&p=127637&hilit=replace+diode#p127637
Luckily I have a spare board and I can use the diode from there. Will try it.. thanks so much !!
bebios
Postby bebios » March 21st, 2017, 9:58 am
Hi.. just to update. Diode D58 seems to be ok.. swapped another diode in and the problems still persists. Any other suggestions would be greatly appreciated. Thanks a million!
bebios
Postby TechGuy » March 21st, 2017, 10:22 am
bebios wrote:Hi all,
I am wondering what is powering your Roomba with the battery removed.
Postby bebios » March 21st, 2017, 6:58 pm
Hi, with the battery removed and robot plugged in the charger, it does not seem to sense that the battery is out, and just continue pulsing orange.. very strange.
bebios
Postby a1robotrepair » March 21st, 2017, 8:57 pm
Without a battery installed, I would expect your Roomba to immediately give a charging error 1, no battery installed.
The Roomba verifies there is a thermistor in the circuit, Qaud op amp U8, A3.
Check out this post, read it throughly. http://www.robotreviews.com/chat/viewtopic.php?t=17151&p=139276#p139276
It's good to be back in the world!
Users browsing this forum: aarolar, cdogstu99, im1kissfan, johnnyh, ps0001, vic7767 and 366 guests
