Roomba 870 side brush not spinning
Postby Nemesis » May 28th, 2017, 6:15 pm
Hi Everyone,
I have a two year old Roomba 870 and the side brush stopped spinning.
There's no dirt or debris, so I ordered a new side brush motor module and assembled it.
It's still not spinning. The spring contacts are intact.
Anyone has any idea about a possible solution?
I suppose it's probably the mainboard but I wonder if anyone has any idea.
Thanks,
Nemesis
Re: Roomba 870 side brush not spinning
Postby a1robotrepair » May 28th, 2017, 7:01 pm
Check connection from Q57, PNP, and Q64, NPN TRANSISTORS collectors to top spring solder connections.
... Q74...Q58...bottom spring.
Q57 & Q74 emitters to VBAT
Q64 & Q58...SysRtn...GND
Postby przemo33 » January 10th, 2018, 4:24 am
Hello,
I also have a problem with a side brush in Roomba 870
"Q57, PNP, and Q64, NPN TRANSISTORS collectors to top spring solder connections.
Q64 & Q58...SysRtn...GND" -> ALL its OK
But I noticed that there is no signal to switch to Q74 in the Base.
Do you know which elements should change the Base (Q74)?
Regards
Side brush S700/800
przemo33
Postby przemo33 » January 13th, 2018, 6:35 am
Hello,
Measurement (V to GND):
A good main plate in green
The wrong main plate is red
The biggest differences around the Q100
Regards
measurment
przemo33
Users browsing this forum: im1kissfan, KeldBroe, knickerbac, mfortuna, Miles267, someoneclever, sondejmarek, symbol and 334 guests
