Roomba 530 dead capacitor x1 ?
Postby John-sausage » July 9th, 2017, 4:26 am
i bought a second hand roomba which was broken with error code 3.
I opened, and it doesn't seems to be a battery leak issue, Q17/Q18 and U8 are clean.
However, in the bottom right corner of the motherboard, i think a capacitor died, as you can see on the picture attached.
Can anyone confirm that it could be the source of the issue? What can i use to replace the component?
Thanks in advance for any help you can provide, i'm a beginner at this stuff, maybe it's a very common component?
John-sausage
Re: Roomba 530 dead capacitor x1 ?
Postby John-sausage » July 9th, 2017, 5:13 am
i found the same companent online i think. Should i just clean a bit around, solder the new one? is there another check i can do?
John-sausage
Postby mfortuna » July 9th, 2017, 7:01 am
if you are referring to the silver object in the center of the picture that is a crystal and the gunk is what glues it to the board. There is probably nothing wrong with it.
Postby a1robotrepair » July 9th, 2017, 11:27 am
x1 is a crystal oscillator. Caps are labeled C(no.).
BIT 11 will tell you the problem.
Spot LED on: Battery voltage between 12 and 18VDC. U8 A2.
Dock LED on: Thermistor Present. U8 A3.
Check Robot LED on: Baseline Current OK. U8 A1 and A4.
Postby John-sausage » August 6th, 2017, 5:54 am
thank you a1robotrepair, your directions are greatly helping me finding the issue!
Fixed the x1 crystall oscillator.
Now i get error 3...
Run the Bit tests, all passings...
BIT 11: spot and dock green, check robot off.
So i was thinking, could it be the charger? i checked the voltage on the charger pad without the robot, and have a reading of 28V, that seems a bit much?
John-sausage
Postby a1robotrepair » August 6th, 2017, 7:24 am
I will assume that your description of "charger pad", you mean the charging base charging plates.
Check again, without load they will read around Two point Eight volts DC.
Postby John-sausage » August 6th, 2017, 11:00 am
yep you're right.
not sure where to look for now. i also tried with a new battery, with same result.
John-sausage
Postby a1robotrepair » August 6th, 2017, 1:57 pm
Check out this thread:http://www.robotreviews.com/chat/viewtopic.php?f=1&t=19964and associated threads.
Users browsing this forum: DeanR181, Flole, johnnyh, mfortuna, mobzd, Rar9, Snokia, teokakav and 351 guests
