Create 2 won't charge
Postby rafaelmarinhoa » July 28th, 2017, 5:11 pm
I had an accident with my robot and some SMD stuff got corroded arround U8, though the IC seems to be fine. I managed to replace the resistores since I found their value, but I wasn't lucky with the capacitors. Could someone tell me what are the values of the capacitors C112, C125, C113 and C89.
By the way, I'm getting charging error 3 and 2, but i'm quite sure the capacitors are faulty.
rafaelmarinhoa
Re: Create 2 won't charge
Postby a1robotrepair » July 28th, 2017, 7:37 pm
I tried to measure their values but was unsuccessful. I kept loosing the LIBDs.
You need a donor board.
Postby rafaelmarinhoa » July 29th, 2017, 2:48 pm
I think the board can run without some of theese capacitors. At least for some time. Is there any guide for testing the board? I could try to guess the value based on the readings. Maybe I'll just replace than with 104/103 ceramic capacitors. What do you think?
rafaelmarinhoa
Postby a1robotrepair » July 29th, 2017, 3:29 pm
rafaelmarinhoa wrote:I think the board can run without some of theese capacitors. At least for some time. Is there any guide for testing the board?
Sure, it will run with U8 totally out of wack, except A2 of U8. Won't charge correctly.
This thread and links in this thread: http://www.robotreviews.com/chat/viewtopic.php?f=1&t=19964
Users browsing this forum: b55er, Harry007x1, vic7767 and 330 guests
