Damaged charging station Roomba - Error 5
Postby przemo33 » August 10th, 2017, 9:20 am
Hello,
Hello,
I have a question about the charging station (integrated).
When charging, after a moment, throws a message "Error 5" on the vacuum cleaner.
On other stations is OK.
Can I somehow repair this damaged station?
Regards
przemo33
Re: Damaged charging station Roomba - Error 5
Postby przemo33 » August 18th, 2017, 5:00 am
Hello
Can anyone help?
Regards
przemo33
Postby a1robotrepair » August 18th, 2017, 11:35 am
They are hardly worth fixing. It's a simple SMPS with a FET switch turned on by the bots load on the charging plates.
Postby przemo33 » August 25th, 2017, 5:32 am
Hello,
Everything indicates that the culprit is this element as for the photo.
(With other good power supply also causes Error 5 error)
Which element can cause such behavior (Error 5)?
Regards
damage element
przemo33
Postby a1robotrepair » August 25th, 2017, 7:29 am
Safety is your no. 1 concern.
That board may, as many SMPSs do, fully rectify and filter the incoming power, making 120V or 220V Ac in to 175V or 310VDC, RMS to Peak.
I recently "fixed" one and didn't take it apart. The power cord wasn't plugged in properly.
Here is the device and a schematic fron the data sheet used by the 4000 series charger.
Users browsing this forum: mfortuna, vic7767 and 330 guests
