Roomba 980 Floor sensor
Postby mqguy » August 29th, 2017, 7:16 am
We have recently bought a Roomba 980 (we've had it 3 days) and already it seems to not be able to detect hard-floors vs carpet. The first day it was fine and worked correctly but now it seems to be on carpet mode (high suction) all the time.
The manual is pretty light on what you need to do. It says just rub a light cloth over the sensor. Well, needless to say we've done that. Anything else we can try ? What type of sensor is it ? The sensor is sort in a finger sized hole - what's at the bottom of the hole ?
Any help would be appreciated,
mqguy
Re: Roomba 980 Floor sensor
Postby vic7767 » August 29th, 2017, 11:05 am
mqguy wrote:What type of sensor is it ?
Firmware 1.4.6 addressed the carpet sensor issue. What firmware release is your 980 running?
Postby raversdelight » August 29th, 2017, 4:20 pm
I have used the roomba 980 for about 2 months and now I have the same problem.
I have tried to clean all sensors and nothing helps.
Would also appreciate help :)
raversdelight
Postby mqguy » August 29th, 2017, 6:03 pm
Thank you for your reply. The App tells us that the Robot software is up-to-date and running V2.2.11-4 which was installed on August 26th.
mqguy
Postby vic7767 » August 29th, 2017, 8:28 pm
BTW, I forgot to post that the carpet sensor is an optical sensor.
Postby myroomba » September 8th, 2017, 2:52 pm
Try to reset your Roomba.
myroomba
Users browsing this forum: a1robotrepair, Aniseedvan, Metalworker, Miles267, mobzd, someoneclever, symbol, vic7767 and 404 guests
