Have anyone replaced the Roomba fan motor?
Postby Per L » December 8th, 2017, 8:59 am
Have anyone replaced the Roomba 500-600 dust bin fan motor?
The model is RC500-KW-16260 (S.M.C. MOTOR) with this specifications (I guess)
Roomba fläktmotor.pdf
(104.38 KiB) Downloaded 2020 times
I have found a lot of motors on eBay, Amazon etc with the same dimensions but they have all lower output and/or lower rpm
Have anyone found a solution that works?
171215: A new link to the specifications for this specific motor
180902: Link no longer working. Enclosed document instead
Per L
Re: Have anyone replaced the Roomba fan motor?
Postby DG59 » January 2nd, 2018, 10:16 am
Hi - just replaced mine with this motor from EBay -
Item No: 252958360223 - only £2.29 so I now have a couple for spares.
Chinese seller - but arrived in less than two weeks over Xmas so not too bad. Seems to be the same spec as original yellow motor - works fine with impeller running at full speed!
Hope this is what you are looking for.
DG59
Postby Per L » January 4th, 2018, 1:29 pm
Yes, I have also found that motor but....
The original motor is RC500-KW-16260 with the specification 12V and a no-load speed 11570 rpm
The motor you have bought seems to be a RC500-KW-16360 with the specification 3-6V and a no-load speed 2000-4280 rpm
https://www.ebay.com/itm/DC-3V-5V-6V-42 ... SwX61ZJOy-
For sure the rpm will be higher than 4280 rpm when you feed it with 12V (I guess around 8500 rpm) but I guess the lifetime will probably be short
But the price is low and it is easy to replace so a short lifetime is perhaps not a big problem.
Can you please give us a feedback in half a year or so if it still is running
Per L
Postby DG59 » January 4th, 2018, 10:09 pm
Hi - oops - yes it does seem to be a lower spec.
However it does seem to run with same suction as original - I will post an update in a few months - or sooner if it fails!
DG59
Postby DG59 » August 31st, 2018, 8:01 pm
Update -
Motor still running ok at 7 months!
DG59
Postby leonicholson » August 31st, 2018, 9:00 pm
DG59 wrote:Update -
Good to know. Will order a couple for spares.
leonicholson
Postby matofill » September 3rd, 2018, 3:40 pm
Today, no link to Ebay does not work anymore, so does enybody has a link, to Ebay, which still works for motor ?
:help:
:thanks:
matofill
Postby leonicholson » September 3rd, 2018, 9:14 pm
https://www.ebay.com/itm/272998790698
I've never replaced one, just ordered one "in case".
leonicholson
Postby gaiger2002 » September 12th, 2018, 10:08 am
I replaced my broken motor with this and it works properly. Thank you for the suggestion
Now it's sold out on ebay... I hope it will be available in the future to purchase some as spares for the future...
gaiger2002
Users browsing this forum: fufu, lanchez, meemaggie, skimmer and 322 guests
