Scooba 5900 immediate drying mode
Postby madbulldog » December 29th, 2017, 12:56 am
I have a Scooba 5900 which I just bought used. The machine turns on and puts water on the floor as well as picks it up. However, after running for only a few minutes it goes into drying mode. (Clean button flashing green and blue) After 5 minutes of this it turns off for completion of the cleaning/drying cycle. If I turn it back on it does the exact same thing.
For troubleshooting I have used a known good battery from another scooba and it does the same thing. I have also put a known good tank and brush assembly on the malfunctioning unit with the same results.
I contacted iRobot who stated they believe it is a software update, but this is not available anymore. Does anyone have an idea on how to fix this problem? If it is a software update needed, how do you do it? I see a round serial port on the inside of the unit, but I do not have the cable or know how to push the software to the unit from a PC.
madbulldog
Re: Scooba 5900 immediate drying mode
Postby mfortuna » December 29th, 2017, 8:43 am
There is no way to update via a PC. You need a dongle known as an OSMO. I forget if the 5900 is the scooba that requires a slightly conductive cleaning solution or else it thinks the tank is empty. Try searching the forum.
Postby vic7767 » December 29th, 2017, 9:33 am
mfortuna is right. The 5900 requires more than just water to operate correctly. Try adding a cap-full of clear vinegar to the clean tank.
Postby madbulldog » January 1st, 2018, 5:31 pm
How much vinegar should you add to the tank? I am searching for the exact amount recommended, but no luck.
madbulldog
Postby vic7767 » January 1st, 2018, 6:17 pm
Use 1/4 cup into a full tank.
Postby madbulldog » January 5th, 2018, 12:00 pm
So it is working like a charm now. It was a combination of 2 things.
1. Battery had not been used in a while and needed to be run several times to get cycled. By discharging it and recharging it 4 times it was able to run longer. It now runs over an hour on a single charge.
2. Mixture was too lean on vinegar. I upped the vinegar/water ratio and it now runs without going into drying mode until the clean water tank is completely empty. I used vic's ratio of 1/4 cup vinegar per tank.
Thanks everyone!
madbulldog
Postby vic7767 » January 5th, 2018, 12:43 pm
:cheers:
Users browsing this forum: joyride76, lanchez and 300 guests
