5 year old 650 not charging
PostPosted: January 1st, 2018, 12:03 am
by JiminSTLouis
Hello
My daughter borrowed our 650 for a couple of years and I just took it back today. It looked liked it was never cleaned or the bin emptied. After a thorough cleaning, I tried charging it and after about a half an hour, I received a charging error 5. All charging contacts are clean including the battery compartment contacts. I did a reboot by holding down the spot/dock buttons but still get the error. Is the battery ready to be replaced or is there something else I can try?
PostPosted: January 1st, 2018, 12:12 am
by DeanR181
JiminSTLouis wrote:Hello
Hi Jim, 6 years for a battery is good going. If the charger is still putting out power, it certainly sounds like a new battery is needed.
Re: 5 year old 650 not charging
PostPosted: January 1st, 2018, 1:01 am
by JiminSTLouis
I’m afraid you may be right Dean. I have the power cable plugged directly into the bot and get the pulsing amber charging light for about a half hour until the error. I’ve tried about 5 times tonight.
PostPosted: January 1st, 2018, 11:17 am
by JiminSTLouis
I ordered a new (oem) battery from Amazon Prime. Hopfully the bot will be back up and running again in a couple of days.
PostPosted: January 1st, 2018, 4:32 pm
by DeanR181
JiminSTLouis wrote:I ordered a new (oem) battery from Amazon Prime. Hopfully the bot will be back up and running again in a couple of days.
fingers crossed that it will resuscitate little bot.
PostPosted: January 5th, 2018, 5:56 pm
by JiminSTLouis
New battery is installed, charged and the bot is back to work!
PostPosted: January 5th, 2018, 9:49 pm
by DeanR181
Excellent, glad to hear it..
PostPosted: January 5th, 2018, 10:04 pm
by JiminSTLouis
DeanR181 wrote:Excellent, glad to hear it..
It’s funny... it never used to go up onto my rugs now it plows right over the edge and vacuums all of them.
PostPosted: June 10th, 2018, 1:57 am
by GraceL
I have similar problem, but my iRobot does not showing any light and not responding. What should I do?
PostPosted: June 10th, 2018, 7:47 am
by a1robotrepair
More info needed.
What does it do when placed on the base?
What does the base do when Roomba is placed on it?
PostPosted: June 10th, 2018, 9:48 am
by GraceL
Google solution, reset the iRobot and use direct charge. Yet charging error 3 still showing. Tried multiple time to reset the iRobot, charging error 2 showing.
PostPosted: June 10th, 2018, 11:00 am
by a1robotrepair
Charging error 2 and 3.
You can search this forum for multiple threads about CE3 & CE2.
Typically one must disassemble the robot, remove the circuit board and clean it.
The best way to clean it is with an ultrasonic circuit board tank, then dipping it in a tank of 99.9% IPA.
Another way is to use 99.9 IPA and a soft toothbrush, cleaning around U8 and its passive components.
If there is a lot of corrosion use a baking soda solution to remove deposits then clean very well with IPA.
This thread has good info on U8: http://www.robotreviews.com/chat/viewtopic.php?t=17151&p=139276#p139276
