New battery, will this work?
Postby rehofdk » January 2nd, 2018, 6:12 am
I got and Roomba 564 Pet that need a new battery.
The battery that is in it now is an original Roomba 3000mAh battery. Some online stores sell 4500 mAh batteries, so the quistion is: Can my Roomba enjoy the bigger battery and can it fully charge it without any problemes, og should i just buy a 3000mAh again?
Thx, Rehof
rehofdk
Re: New battery, will this work?
Postby vic7767 » January 2nd, 2018, 10:04 am
Your Roomba can work quite well with the larger capacity packs.
Postby Brett » January 2nd, 2018, 6:57 pm
It certainly will work. However there are a few "gotchas".
I have had mostly bad life (longer running times but bad replacement life) from the larger batteries - maybe they are less "durable"? Use 3000 > 3500 and run the machine more frequently (if needed).
Also consider going to Lithium if you want longer run-times...
Users browsing this forum: DeanR181, johnnyh, mraiteri and 381 guests
