Roomba 775 (aka 770) issue : turns in circles and no sound
Postby Nano69 » January 29th, 2018, 9:36 am
Recently bought a Roomba 775 (which in fact seems to be a 770 board) for a cheap price, but out of order. I’m trying to repair it…
Roomba switched off, I press one time the clean button and it turns on normally (active keyboard, screen OK, but no sound).
When I press the clean button one more time, it starts (bin motor ok, brushes OK, right wheel OK, side brush OK, but left wheel doesn’t work) and turns around itself. The left wheel does not work.
Tried to replace the left wheel, and the bumper sensors, but it didn’t change anything.
A few voltage measures on the main board pointed out that after starting up the Roomba (the first time clean button is pressed) :
U25 (TPA 751), 0,9 V between pin 7 (GND) and pin 6 (V+) => this is audio amplifier, it cannot work if not powered => no sound, ok… :D
U10 (LM358), 0V between pin 4 (GND) and pin 8 (V+), :shock:
U2 (LM393) 0V between pin 4 (GND) and pin 8 (V+), :shock:
U1 (LM324), 6,15V between pin 11 (GND) and pin 4 (V+)
It seems like a part of the board is not powered….
Any idea ?
Many thanks for your help,
Arnaud
Nano69
Re: Roomba 775 (aka 770) issue : turns in circles and no sou
Postby Nano69 » March 23rd, 2018, 10:12 am
Hello,
Still trying to troubleshoot this main board...
Does anyone have this board schematics or any maintenance/troubleshooting guide ?
Many thanks,
Arnaud
Nano69
Postby a1robotrepair » March 23rd, 2018, 10:30 am
http://www.robotreviews.com/chat/viewtopic.php?f=4&t=19533
Go to this thread, under 700/800 look at right wheel H-Bridge thread, it has the info you seek.
There was a time early in the 770s line that many failed for the left wheel.
A few I repaired were bad solder joints on one of the gate circuits of the duo FETs.
Can't remember which one but pushing down with a little force on them, while in bit mode, caused them to run.
Postby Nano69 » March 30th, 2018, 10:05 am
@a1robotrepair : Many thanks for your help. I'll check soldering of duo FETs ...
I also have another problem : U25 (TPA 751) is not powered (no voltage on pin 6), and i don't get any sound.
Don't know if it could be linked with the wheel problem, but i'd like to solve this.
Does anyone know how this chip is powered ? It needs 5V, but where does this voltage come from ?
Thank you,
Arnaud
Nano69
Postby a1robotrepair » March 30th, 2018, 7:17 pm
It is very possible you have lost the 5Vreg to these circuits. It is supplied throughout the board in a substrate layer. Good luck finding the bad point, looks like another jumper. Find the like points in like circuits, left wheel, right wheel circuits, and check a jumper wire from there.
Postby Nano69 » April 9th, 2018, 3:15 pm
Hi
Wired a jumper from U25 pin 6 to R175, and sound came back :D
But this sound problem had nothing common with the right wheel definitly refusing to work ... :evil:
Nano69
Postby Nano69 » April 9th, 2018, 3:24 pm
Sorry, left wheel....
Nano69
Postby sabrina » July 2nd, 2018, 10:14 pm
A similar thing happened to 570... Roomba as it was going in circles and one wheel was not working. The corresponding H bridge was the apparent cause, as changing the transistors in that bridge healed the Roomba. The failure was probably caused in this case by some spill that also coloured that part of the board. We bought the Roomba after it was "cooked". Luckily, now it works, but it needed a lot of work on that MB.
sabrina
Postby Nano69 » November 19th, 2018, 11:38 am
Hi
Back in this thread after a long time… No time to work on my roomba, and my o-scope went out of order which makes it much more difficult in troubleshooting the Roomba !
With a new scope and some extra time, I noticed that the pwm signal doesn’t come to the left h-bridge.
I used a right h-bridge schematic found in another thread but unfortunately it does not detail the left part enough and I need more informations (if not I’ll try to build a left schematic from scratch using my multimeter :( )
On the Right H-bridge, pwm signal comes from MCU28-39, through C90, R161, and in the end Q93.
I guess that Q93 is Q86 on the left part. Am I right ?
But what about C90 an R161 on the left part ? And from which pin of MCU28 does the pwm signal come from ????
And what about U5 ? Is a specific part of U5 used for the left h-bridge ? If yes which pins ????
Many thanks in advance for your help
Nano69
Postby Nano69 » November 29th, 2018, 10:17 am
Hi
Here's the cabling for the right wheel :
My problem is all about the left wheel, and i noticed that the pwm signal doesn’t come to the left H-bridge.
According to the attached schematic, on the Right H-bridge pwm signal comes from MCU28-39, through C90, R161, and in the end Q93.
I guess that Q93 on the right side correponds to Q86 on the left side. Is it true ?
But what about C90 an R161 ? Which capacitor and which transistor is it on the left side ? And from which pin of MCU28 does the pwm signal come from ???? Does anyone know ?
With these informations i would be able to determine if the problem comes from the PCB or a failed capacitor/transistor...
Any help appreciated
Arnaud
Nano69
Users browsing this forum: CarolineHardacre, iangough1000, im1kissfan, johnnyh, mackk, Mattb83 and 358 guests
