Physically disable bin full sensors
Postby CarShopRoomba » April 3rd, 2018, 2:26 pm
We have a concrete floor lobby with lots of fine, sandy dust that accumulates every where. Without fail, our Roomba 980 will error out with a "bin full" error after 2hrs of cleaning. Upon checking the bin, it is only 10% at the most. It's just the fine dust inside causing the IR sensors to freak out.
We changed the setting to allow it to continue cleaning even with the bin full error, but it is still annoying to blow the bin out every morning.
Is there a way to physically disable those IR sensors, so it stops checking?
CarShopRoomba
Re: Physically disable bin full sensors
Postby a1robotrepair » April 3rd, 2018, 4:52 pm
Tape bot sensors with black electrical tape.
Let us know how it works, may take 2 layers.
Goo Gone to remove.
Postby CarShopRoomba » April 4th, 2018, 7:15 am
Interesting. I've seen guys do that to disable the cliff sensors, but won't this make the Roomba think the bin is full ALL the time?
CarShopRoomba
Postby a1robotrepair » April 4th, 2018, 8:34 am
Taping the sensors with black tape is trying to achieve the opposite effect on the sensors. The bin full sensors programming activates with sensors being activated, reflective material between sensor and bin or bin not close to sensors.
This is a trial. I just tried it once and the bot runs. The bin didn't get full but usually gives full signal, not this time. Will it work? Trial and error.
Postby CarShopRoomba » April 6th, 2018, 7:09 am
I'm going to have to give a "no" to this one. Does not work. I put 3 layers of electrical tape all around the bin full sender and receiver on the main body (see picture). Bin sensor still shows BIN FULL after 1-2 cleanings.
My thought is to take apart the body and put the two sensors right next to each other. Thoughts?
CarShopRoomba
Postby TechGuy » April 6th, 2018, 11:52 am
That may work. I did similar hack with the cliff sensors. I put the IR LED and transistor inside a straw about half inches long. If works very well on cliff sensor. Try my hack with bin full sensor and report back.
Postby a1robotrepair » April 9th, 2018, 8:28 pm
Trial and error. I think that cures half the modification you are seeking.
Non-iRobot personnel are not sure how the software processes bin full status.
Other vac-bots look at bin current, when it changes on them is when they report bin full or filter change time.
iRobot could have used this method also, unknown by me.
Try resetting filter changed in app without cleaning the filter.
Again, trial and error.
Postby CarShopRoomba » May 1st, 2018, 9:34 pm
I found the culprit and solved it.
Essentially the physical status of the bin must MATCH the software status of the bin full/empty. For example, if the bin has just been physically emptied, but the bin reset was not clicked in the app, the Roomba is going to get confused.
CarShopRoomba
Users browsing this forum: boyler74, fuzzydunlop, KeldBroe, rob111gb, sondejmarek and 319 guests
