Roomba 531 charging error 3, new battery
Postby torbenc » June 19th, 2018, 7:03 am
Hi
My Roomba 531 started to give me charging error 3, and sometimes it helped to take out the battery, clean the terminals and re-insert it.
It got worse and worse, and suddently the battery seemed dead. And I coulden't even turn on the Roomba.
I replaced the battery, but get a charging error 3 constantly now.
I have cleaned the terminals, and bend dem slightly upwards
I have done a reset of the Roomba
I have used both the dock and the side charger port
Still same error.
Only thing I haven't tried, is to leave the charger plugged in, for some days. It is flashing red, when the charger is plugged in
torbenc
Re: Roomba 531 charging error 3, new battery
Postby a1robotrepair » June 19th, 2018, 7:53 am
You could have searched Charging Error 3 and found a lot of info.
Last edited by a1robotrepair on June 19th, 2018, 11:09 am, edited 1 time in total.
Postby torbenc » June 19th, 2018, 8:11 am
So what makes you think I haven't searched? My post clearly states that I have made attemps to make it work - Do you think I have invented those things my self?
torbenc
Postby a1robotrepair » June 19th, 2018, 8:26 am
You can catch a lot more bees with honey than you can with vinegar.
Postby torbenc » June 19th, 2018, 9:29 am
From my first post.
torbenc wrote:I have cleaned the terminals, and bend dem slightly upwards
I also re-soldered all battery terminals connections, and cleaned the PCB.
U8 has no visual defects on any legs.
torbenc
Users browsing this forum: BCCISProf, iangough1000, mfortuna, minh1010, someoneclever, WingNut and 388 guests
