960 strange charging problem
PostPosted: July 3rd, 2018, 12:20 pm
by flat5
After about a year of daily use, my 960 seemed to be taking longer and longer to finish a job. So I replaced the battery with an aftermarket one off amazon. It seemed to work fine at first.
But now, something really strange is happening. The roomba shows that it is fully charged on the robot itself, with the green battery bar. But in the app, it shows it as almost totally discharged, red indicator that's empty or almost empty. It runs for about 5 minutes, then returns home to charge again.
Any ideas what's going on here? I've seen something about "resetting the charging system" but the instructions were contradictory and not for my model.
Re: 960 strange charging problem
PostPosted: July 3rd, 2018, 1:32 pm
by GSRtrent
The battery you bought off amazon; is that a Roomba replacement battery or a 3rd party battery? Always buy the manufacture replacement battery from their website. You may have gotten a knock off battery. Before it does damage, I would remove it and put the old one back in. See if the charging behavior changes. If it does then you know it was the new battery. Buy a new battery off their website. Don't try to go cheap on it either as it's a very important part.
PostPosted: July 3rd, 2018, 6:13 pm
by a1robotrepair
GSRtrent wrote:The battery you bought off amazon; is that a Roomba replacement battery or a 3rd party battery? Always buy the manufacture replacement battery from their website. You may have gotten a knock off battery. Before it does damage, I would remove it and put the old one back in. See if the charging behavior changes. If it does then you know it was the new battery. Buy a new battery off their website. Don't try to go cheap on it either as it's a very important part.
I agree with GSRtrent!
There is only one known aftermarket battery which is good. LithiumPowerInc.
PostPosted: July 3rd, 2018, 11:16 pm
by flat5
It is a 3rd party battery. But, I don't know of any reason why a 3rd party battery couldn't be just as good as the OEM.
It's this battery here:
https://www.amazon.com/gp/product/B00SW ... merReviews
which seems to have a pretty good track record.
Rebooting the robot by holding down the clean button for 10 seconds seems to have fixed the discrepancy between the green light on the robot and the red light in the app. Both show it fully charged now. Let's see how it runs...
PostPosted: July 5th, 2018, 12:32 pm
by flat5
It seems to be operating normally after resetting the robot by holding down clean for 10 seconds.
