T'shooting Dead 595 -- Found a Smoked Transistor
Postby lothian » July 21st, 2018, 12:11 pm
My 595 collided with a water bowl. The thing went quiet after the crash, and that got my attention. I found the Roomba completely unresponsive, and with curl of smoke rising from the control bezel. Smash-cut to a fully-disassembled Roomba strewn across my work table.
With the help of a magnifying glass, I believe I've identified one--and only one--obviously smoked component: a transistor, Q79 on the mobo (see attached images).
My plan, of course, is to replace this transistor with identical--hopefully, that effort is all that's necessary to revive this appliance in lieu of doing a wholesale mobo swap. I have no idea what the specs are for this component. And so I turn to this forum. Any assistance is appreciated.
lothian
Re: T'shooting Dead 595 -- Found a Smoked Transistor
Postby a1robotrepair » July 21st, 2018, 1:14 pm
That board is water damaged.
Highly unlikely you will be able to resurrect it.
Q79 is the switched transistor for the vacuum bin.
Replacing it will not cure your problems.
A 560 light early 650 main board may fix your problems.
Search this forum for testing the modules, CHM, Wheel, Bin and Side Brush / Front Brush.
Postby lothian » July 26th, 2018, 9:10 am
Thanks for the response.
I'd like to swap in a new transistor prior to t'shooting the board. Do you happen to know the specs for this specific component? Optionally, do you have one laying about you can offer?
lothian
Postby a1robotrepair » July 29th, 2018, 12:56 pm
It is the bin power transistor.
Your picture shows at least 1 bad capacitor.
The traces from the power diodes look bad.
Q79 is a S8050.
Users browsing this forum: ASTMedic, jdong, johnnyh, mfortuna, Rar9, RockinRay, someoneclever, Stanleymarshall and 363 guests
