Roomba 590 all brushes stopped
Postby Phiggystardust » July 29th, 2018, 6:11 am
Can anyone help all was fine now all brushes have stopped all is clean on both main and side brushes inside gearbox too ! Any thoughts most welcome
Phiggystardust
Re: Roomba 590 all brushes stopped
Postby a1robotrepair » July 29th, 2018, 1:07 pm
More than likely the Cleaning Head Module motor is bad or full of dust and dirt.
Postby Phiggystardust » August 7th, 2018, 4:14 pm
thanks for your reply
strange that both the main and side brushes have stopped , no errors either
Phiggystardust
Postby vic7767 » August 8th, 2018, 11:57 am
Go here: http://choisirsonaspirateur.info/wp-con ... Manual.pdf
and download the Service Manual. Read through the manual and see how to run the MANUAL BiTs mode. This may help you determine the cause of motor failure. If you can monitor the SCI channel during the tests much info about the health of the brush deck motor and side brush current consumption may be discovered.
Users browsing this forum: ASTMedic, jdong, johnnyh, mfortuna, RockinRay, someoneclever, Stanleymarshall and 357 guests
