Roomba 760 dock charger current
Postby wildjohn » August 10th, 2018, 2:14 am
Hi all
All of a sudden 2 days before the roomba could not be charged on the dock.
After a few attempts to clean the contact points which didn't solve the problem, i got my multimeter and i saw that the current from the cable on the wall that plugs on the dock is 24V while the current on the pins that touch the roomba is 2.3 - 3 V
Are these numbers correct or i should find a new dock?
Στάλθηκε από το HUAWEI VNS-L21 μου χρησιμοποιώντας Tapatalk
wildjohn
Re: Roomba 760 dock charger current
Postby Brett » August 10th, 2018, 8:34 am
Those are correct. Search for "charging Jack" here and you'll find the probable cause...
Postby wildjohn » August 10th, 2018, 8:58 am
Thanks for the tip... i will search for it asap
wildjohn
Postby wildjohn » August 12th, 2018, 12:35 pm
So after a few hours spending on checking the bot with the charger, i came yo the conclusion that all that was needed was a good cleaning on the contacts.
What came up now is that the battery seems to be damaged because all the times i left the bot cleaning i came back home finding it on random spot out of power.
How can i be sure that the battery is faulty?
Any tip on this?
Also is there any upgraded battery (if it needs replacement) with more capacity or better in any way?
wildjohn
Users browsing this forum: ASTMedic, jdong, johnnyh, RockinRay, Stanleymarshall and 352 guests
