vic7767 wrote:The pack in the i7 is marked 1800 mAH and 14.4vdc
My previous post was to point out the battery cavity size, not to attempt a pack hack.ps0001 wrote:That's a great idea,
ps0001 wrote:As far as we know, 900 series Roombas cannot split floorplans into individual rooms, but we also don't know that the i7 does this on-board. It's just as likely that this happens in the app or on an iRobot server. Room manipulation and naming occurs in the app.
I just can't believe there's a technical reason the 980 won't get this feature. Hopefully someone like Vic will bless us with a partial teardown of the i7 so we can compare hardware. The processor in the 960 and 980, the STM32F1, is very much an active part.
Probably, 960/980 already work on the edge of their CPU power, so porting the new code would slow down them even more... They certainly wrote it for the more powerful CPU.The 980 during “edge clean” seems to try to nudge basically every 2 feet of wall hoping to find a doorway, and when it doesn’t it pauses for a few seconds to update its internal map.
TerrenceBlack wrote:What you wrote makes sense to me, maybe it's technically possible to add this features to 960 and 980. But the firmware is certainly hardware-dependent, they made a new hardware, then wrote a new code. Now, even if it's possible to port it to the 960/980 hardware, they should do some additional work and as a result, a lot of 960/980 owners will get "almost i7" and the chance they will upgrade to i7 is minimal. So, to do some work to lower profit is not what a business wants.
Regarding processing data on an iRobot server, it looks like due to security concerns, they don't do that and all the computing is done on-board.
gregj wrote:So I wonder if they are going to be now selling the house layout information out to companies offering them monies for it? That was their plan to make more monies in the past, as per iRobot CEO statements.
wat wrote:those with a working i7 - do any of you use the android app to manage it?
irobot is sending me a replacement roomba due to a software bug in some of the units. just trying to determine if something triggers the bug, or if its simply a defect with a percentage of them.
ps0001 wrote:So I broke down and got an i7 yesterday.
TerrenceBlack wrote:So how does it work on black surfaces?
ps0001 wrote:TerrenceBlack wrote:So how does it work on black surfaces?
Just as advertised. No issues over the same areas the 980 struggled with.
It's pretty good overall, but still a bit clunky. I'm hoping the whole experience is smoother with future firmware and software updates. For instance, the Android app has some serious bugs, and I'm kind of disappointed with how tedious it is to build a map. I made the mistake of letting my Roomba build a map with one of the bedroom doors closed. This morning I sent it on a cleaning/training run to add that room, but apparently you have to delete the previous map and build a new one (if anyone else has experience with this, please tell me if I'm wrong).
TerrenceBlack wrote:Yep, it's hard to be a robot in the humans' worldNever know if it's a door or a wall
How does it work in the dark rooms? And what about boost on carpets? Does it change the fan power depending on the flooring, like 980 or goes on constant power all the time?
Users browsing this forum: im1kissfan, jdong, johnnyh, leonicholson, Miles267, vic7767, wassct and 399 guests
