Replace Roomba Tires
Postby leonicholson » September 22nd, 2018, 7:54 pm
Out of curiosity, I bought a used Roomba that needs new tires. Just want to test different methods I've found on the internet. These Kirby belts turned inside out are said to fit well. Will see.
Last edited by leonicholson on September 23rd, 2018, 11:22 am, edited 1 time in total.
Re: Replace Roomba Tires
Postby rotorwash » September 22nd, 2018, 8:12 pm
you can buy the whole wheel assembly from Irobot for 29 dollars
rotorwash
Postby leonicholson » September 22nd, 2018, 8:41 pm
Takes the challenge away. :)
Plus, this is a $2.50 repair for both wheels on a $36 Roomba.
Last edited by leonicholson on September 26th, 2018, 9:01 pm, edited 1 time in total.
Postby Brett » September 24th, 2018, 9:26 am
I buy kid-size silicone arm-bands (in funky bright colours) and they work a treat. They are okay just stretched into place, but I usually put some glue on to hold them.
I think I paid $5 for 10 pairs last time...
Postby leonicholson » September 24th, 2018, 9:38 am
Received the ($36) Roomba 665 today. Works normally.
Just put the kid bands on for testing (without glue).
Seems to work ok with the bands, but they do slip off without glue. (I don't want to permanently attach yet).
Will test Kirby belts when they arrive.
After
Before
Postby leonicholson » September 26th, 2018, 2:23 pm
Received the Kirby belts and fit them over the existing worn tires.
Very tight fit. The treads are the same width as the originals and have a good tread pattern.
Just ran the vac for 135 minutes. Tires still straight (without glue).
Not bad for two $1.25 tires which brings the cost up to $38.60 total for a vac that cleaned up like new and turned out to have a strong iRobot battery.
Postby Kelad » September 27th, 2018, 6:32 am
Some good ideas here from you guys. Thanks. I have also tried 3D printing treads from thingaverse and they came out good. Those roombas must have done alot of km's over the years to wear the tire down so much !
Kelad
Postby matofill » September 27th, 2018, 8:39 am
Do you have some links, where we can buy Kirby belts or similar ?
:thanks:
I found : https://www.ebay.de/itm/Ersatz-Vacuum-K ... sjTOic7rRA
matofill
Postby leonicholson » September 27th, 2018, 9:27 am
Kelad wrote:Those roombas must have done alot of km's over the years to wear the tire down so much !
I have no idea. I expected it to be very worn all over.
In fact, nothing but the tires showed any wear at all.
Just very, very dirty.
Last edited by leonicholson on September 28th, 2018, 8:35 am, edited 1 time in total.
Postby leonicholson » September 27th, 2018, 9:31 am
matofill wrote:Do you have some links, where we can buy Kirby belts or similar ?
:thanks:
These are the ones I bought.
https://www.ebay.com/itm/253388587957
Fits Classic, Heritage, Legend, Generation 3, G4, G5, Gsix, G7, G7D, G10, G10D, G2000, Kirby Ultimate G, Diamond, Sentria & Avalir models. Kirby Part Number 301291.
Postby leonicholson » November 1st, 2018, 12:28 pm
leonicholson wrote:. Tires still straight (without glue).
Update
After several days, one belt slipped sideways. Used some rubber tire cement between the old tire and the Kirby belt. Several weeks without a problem so far.
Update
Several weeks of daily usage without a problem so far.
Users browsing this forum: ASTMedic, BrettS, jdong, RTC and 168 guests
