Scooba 230 charger for extra battery?
Postby Botty » October 7th, 2018, 5:50 pm
Firstly, is it possible to hot-swap batteries in & out of the scooba 230 to perform cleans one after another, as with the braava 240. Or is it like the other scoobas where you have to use a trick like vic's button presses & battery ejection to fool it into carrying on cleaning?
Secondly, if it's possible to stick a second battery in once the first is depleted, is there such a thing as a standalone battery charger so you can charge one battery in the scooba while it's plugged in and then a second in a charger, again much like the braava 240 or the 3rd party battery chargers available for other scooba batteries?
Botty
Re: Scooba 230 charger for extra battery?
Postby vic7767 » October 7th, 2018, 8:21 pm
Yes, you can hot swap packs in the 230. It is nothing like the 450s. You will need an external charger and you will need to make your own connector.
Postby Botty » October 7th, 2018, 8:29 pm
Thanks as ever, Vic.
I presume from your comment that there’s no first or third party charger available that you’re aware of?
Botty
Postby Botty » October 7th, 2018, 8:33 pm
Oh and one other question. I believe the 230 battery is 1300mah. I’ve seen some 1500mah for sale. If I put a 1500mah or larger in the 230 would it run for longer, or would it hit its 40 minute mark then demand a recharge, regardless of how much power is left in the battery? (that was what made me think of your 450 trick)
Botty
Postby vic7767 » October 7th, 2018, 9:10 pm
A larger capacity battery will increase the run time.
I have not seen any 3rd party external chargers for the 230 packs.
Postby Botty » October 8th, 2018, 12:52 am
Aha, great news. Have you ever seen a battery larger than 1500mah for the 230, on your travels?
Botty
Postby Brett » October 8th, 2018, 1:06 am
Botty wrote:... is there such a thing as a standalone battery charger ...
They are not the best quality but look at one of these off eBay...
Postby Botty » October 8th, 2018, 1:08 am
Thanks, although doesn’t seem built for a 230?
Botty
Postby Brett » October 9th, 2018, 12:46 am
Sorry - my bad. Had a brain fart and didn't register you were talking about the little Scooba...
)-8
Users browsing this forum: BCCISProf, JudeEdwards, kersian, linvinus, Miles267, minh1010 and 355 guests
