irobot i7 home base same as irobot 780?
Postby orionteo » October 19th, 2018, 2:51 am
Like to check if the home base and power chord jack is the same for the irobot i7 and the irobot 780? Or is the power chord jack to the home base the same?
Thanks much!
orionteo
Re: irobot i7 home base same as irobot 780?
Postby ps0001 » October 19th, 2018, 2:36 pm
The integrated bases use different power cords than the older ones, but the base itself should be compatible. My i7 uses the same base as my 980, which could also use the base from my 530.
ps0001
Postby orionteo » October 19th, 2018, 5:23 pm
Thanks! I am referring to just the home base of the i7 and not the i7+ with the integrated base.
So i7 home base is similar to all past Irobot Homebase. That is really good then
orionteo
Postby vic7767 » October 19th, 2018, 5:45 pm
700, 800, and 900 model Roombas have integrated power supplies internal with the home base. 600, 500, and 400, 4000 home bases had external power supplies that plugged into the home bases.
Users browsing this forum: ed@tenholder.net, im1kissfan, Ionic, jdong, johnnyh, jtheruler791, mfortuna, OldeScoobaGuy, rotorwash and 301 guests
